  #61 (permalink)
Old 08-28-2017, 10:47 AM
eaf1956's Avatar
Originally Posted by N4KVE View Post
SMA connector hasn't broken off yet like so many others?
No SMA is fine so far!
Current scanners:BCD 996XT,BCD996P2
BCD536HP (2)
Ham Gear: Icom 7000, U82, V82, V8, IC 2820, MD2017, Vertex Standard EVX 539, MD 9600 and a YAESU FTM400DR
  #62 (permalink)
Old 08-28-2017, 1:49 PM
eaf1956's Avatar
OK TYT released updated firmware and Programming software and now all is GOOD on the MD 9600.
A lil note: While the new software appears to import MD2017 codeplugs, when I wrote mine to the 9600, the radio is frozen. It won't transmit and the controls are frozen. I went back to one of my original test codeplugs (less information) and all works fine. That codeplug was coded using the 9600 software.
BCD536HP (2)
  #63 (permalink)
Old 08-29-2017, 9:58 AM
sorry for this mobile TYT MD-9600
1) the CPS and SW to program is the same of the MD-2017 or not ?
2) is possible to put and see the all WW database of the ham-radio (call, name etc... ) ?
best 73
  #64 (permalink)
Old 08-29-2017, 10:29 AM
eaf1956's Avatar
best 73
1) No, not the same
2) not at the moment, I don't think the screen has the space anyway
BCD536HP (2)
  #65 (permalink)
Old 08-30-2017, 8:44 AM
thanks.... you say not space (is not little.....) for see on the display the Callsing , and other info of
the ham-radio in rx , NOT GOOD this by TYT !
73
  #66 (permalink)
Old 08-30-2017, 4:13 PM
eaf1956's Avatar
73
You can see the callsign IF you have that person in your contact list!
BCD536HP (2)
  #67 (permalink)
Old 08-31-2017, 8:29 AM
eaf1956's Avatar
And today 8.31.2017 TYT released another firmware update for the MD9600 radio. This is version 3.29 replacing the 3.28 version which was released to fix the radios that were shipped not working.
BCD536HP (2)
  #68 (permalink)
Old 08-31-2017, 8:32 AM
Drumbum's Avatar
All else fails make it work after the customer gets it, I'm still keeping my eye on this radio until all the bugs are worked out and they're readily available I really want this mobile
Sent from my VS995 using Tapatalk
  #69 (permalink)
Old 08-31-2017, 11:20 AM
eaf1956's Avatar
The old programming software did NOT work, the old firmware the radio shipped with did NOT work. Since then they came out with new programming software (went from 1.12 to 1.18) and new firmware 3.28 was the first one that worked and now 3.29 is out. Works as I updated to 3.29 this morning. Waiting for the 100K contacts thing if they can even do that on the 9600 with the display being so small.
BCD536HP (2)
  #70 (permalink)
Old 09-01-2017, 3:32 AM
1) the NEW fw solved the problem is not programmed in vhf ?
2) after the add od the call in the list of the radio.... there is NOT the
possibility to add like the MD380tools or ToolZ to see all the ha-radio calls of the world ?
  #71 (permalink)
Old 09-12-2017, 7:27 PM
Does the dual band TYT MD-9600 have simultaneous receive? What about cross band repeat?
  #72 (permalink)
Old 09-13-2017, 1:19 PM
No, and no again.
Bill
N4GIX - Ham / WQWU626 - GMRS
VV-898, TK-840(N), 2xTYT-7800, 2xUV5R v2+, HP1, BCD436HP, TMV7A, Ritron RRX-450 Repeater, MD-380, XPR7550, 2xCS800, Bridgecom BCR-40U Repeater, Elecraft KX3 + PX3
  #73 (permalink)
Old 09-13-2017, 1:23 PM
That's too bad. I can't fit it in the car and I need crossband repeat around the house. TYT is coming out with some nice stuff but they need to add a Ham or two to their engineering and design staff.
  #74 (permalink)
Old 09-15-2017, 2:32 AM
The 9800 has that. The 9600 does not. If you can give up DMR, go with the 9800.
Tags
dmr, md-9600
