  #21 (permalink)
Old 09-15-2017, 4:42 PM
I'm guessing that this mod doesn't work then: Baofeng_BF-888_Modifications
  #22 (permalink)
Old 09-15-2017, 4:49 PM
davidzimmerman's Avatar
i would give it up ant888 seems you don't understand radios from VHF to UHF just use the scanner
  #23 (permalink)
Old 09-15-2017, 4:52 PM
I just wanted to know if the mod even works...
  #24 (permalink)
Old 09-15-2017, 4:55 PM
Looks like BS to me. No mention of any specs. Did they test the transmitter power output, harmonics, spurs and and receiver sensitivity and selectivity on the hacked frequency ranges?
Some of these CCRs can be made to display any frequency from 000.0000 to 999.9999 but the radio won't actually work outside the range it was designed for because of hardware limitations.
Tom
  #25 (permalink)
Old 09-15-2017, 5:13 PM
ant888 question why do you need a radio when you have a scanner?
do you belong to a department?
  #26 (permalink)
Old 09-15-2017, 5:14 PM
I don't have a portable scanner. That's why I'm looking for mods.
  #27 (permalink)
Old 09-15-2017, 5:17 PM
buy a pocket scanner and give up on a radio the scanner can do 100% more for you and be LEGAL
  #28 (permalink)
Old 09-16-2017, 12:57 PM
I emailed the guy who made it, and he mentioned something about using Chirp to edit the radio's control settings, not too sure what that means.
  #29 (permalink)
Old 09-16-2017, 1:05 PM
KK4JUG's Avatar
Google it. Chirp is generic-type programming software that works on a lot of radios, mostly Chinese.
  #30 (permalink)
Old 09-16-2017, 1:08 PM
I already Googled it. I've seen many people do this to their bf888s, but there are no tutorials available.
Sent from my SM-T710 using Tapatalk
  #31 (permalink)
Old 09-16-2017, 1:46 PM
jonwienke's Avatar
Not likely. Adding VHF freqs requires hardware changes to the radio, not just software tweaks. The radio is UHF only.
  #32 (permalink)
Old 09-16-2017, 2:07 PM
KK4JUG's Avatar
Like he said, VHF is pretty much out of the question. That's why I suggested that you read up on the very basics so you'll understand the differences and varieties. You don't need to be a Marconi or jonwienke. You just need to know the basics.
It would cost much, much more to modify it than the radio cost and, although I have one, it's not all that great a radio in the first place.
  #33 (permalink)
Old 09-16-2017, 6:13 PM
How do you explain this video then? https://youtu.be/FNHXVVgwM9I
Sent from my SAMSUNG-SM-J326AZ using Tapatalk
  #34 (permalink)
Old 09-16-2017, 6:40 PM
i never seen a radio that's UHF and add VHF to it still BUY a scanner ant888
  #35 (permalink)
Old 09-16-2017, 6:45 PM
Did you watch the end of the video
  #36 (permalink)
Old 09-16-2017, 6:51 PM
i did still a junk radio
  #37 (permalink)
The point is how did he get it to work like that?
  #38 (permalink)
Old 09-16-2017, 6:53 PM
he knows how that's how lol
  #39 (permalink)
Old 09-16-2017, 7:03 PM
So it's fake?
  #40 (permalink)
Old 09-16-2017, 7:07 PM
i don't know still can't see making a UHF radio do VHF like many other trying to tell you it don't have the requires hardware for VHF if it was DUAL BAND it would have UHF and VHF in it NO tricks in programming.
