Old 03-20-2017, 4:35 PM
Default Encryption
I have a TR-7400 Uhf radio and it has an encryption setting, but I can not find any info on frequency or numbers to program...Any help most appreciated.
Old 03-20-2017, 4:45 PM
If you don't even know what frequency you're dealing with, then you shouldn't even be thinking about encryption.
Encryption is not legal in the ham or GMRS bands.
What are you trying to do?
Old 03-20-2017, 4:57 PM
Default Encryption
First of all the TR-7400 is a business band radio. Even though I have amateur frequencies programmed, It is primary for my security and LE use.
Secondly I know the frequency that I'm using, but as like any system you have both analog and digital PL's. Those PL's ARE frequencies.
Old 03-20-2017, 5:42 PM
It doesn't matter if it's a "business band" radio, if you're transmitting on amateur or GMRS frequencies, you can't use encryption. Encryption is allowed on business and public safety frequencies.
There's no such thing as a digital PL frequency. You have DCS (digital coded squelch) codes or talkgroup IDs, both of which are digitally encoded numbers, not frequencies. CTCSS (Continuous Tone Coded Squelch System) tones are frequencies between 67 and 254 Hz that are mixed with modulated audio, but are completely separate and independent from the RF transmit frequency (somewhere between 400 and 480 MHz). And neither DCS or CTCSS have anything to do with encryption.
Once again, what are you trying to do, and on what frequency are you trying to do it? What system are you trying to communicate with using encryption?
Old 03-20-2017, 6:57 PM
You sure about that?
Old 03-20-2017, 7:59 PM
I didn't think that radio did encryption either...
Old 03-20-2017, 8:27 PM
Not having this radio, but just downloaded and looked at it's programming software and does say encryption in it. Most likely like basic Privacy in other DMR radios
KB3QWC
Old 03-20-2017, 8:46 PM
buddrousa's Avatar
Your twoway radio shop that programs the Police Radios or the Police Radio System Administrator has the info you need. But you will still have to have permission from the Department to use Encryption. I have never known the Encryption Key info let out of a Radio Shop.
Support your local FIRE & EMS. PRO197-106-18-107-668:PSR-410 X2: BC8500XLT 785d BCD436HP BCD536HPx2 BCT346 BCD996P2 x2 BCT15 BCT15X2 TRX-1 TRX-2 EFJ51SL MTX8250 Tk280 TK2180 MD380x4 Buddy
Old 03-21-2017, 3:00 PM
Maybe you're right. I couldn't find anything in the literature about it, but I haven't looked at the software.
Tags
programming encryption
