Yes the CS580 Update to 1.1.0 is a bit more complicated than before. Here are the steps needed to update the firmware.
1. Go to:
Connect Systems
2. Download the first four files shown. These are: "update_firmware_CS580_V1.1.0.bfup", "ENGLISH", "SAVING THE ENGLISH FILE.docx" and "Updating CS580.docx". Note that the file named ENGLISH has no extension.
3. If you had not performed an update previously, go to the item "Firmware Update Zip Files" (4th from the bottom) and download the "BFP_UPDATE.zip" file. This ZIP file contains the program files needed to update the firmware. Ultimately you will unzip these files into the "C:\Program Files\BFDX\BFP_UPDATE" folder (using the instructions in the next step).
4. Follow the directions in the "Updating CS580.docx" document. This will allow you to update the firmware to V1.1.0 using the "update_firmware_CS580_V1.1.0.bfup" file downloaded previously.
5. Follow the directions in the "SAVING THE ENGLISH FILE.docx" document. This will allow the CPS software to communicate with the CS580.
The new features are described in a "New Features" document located on the following page. This page also has the SC580 Users Manual and CPS Manual.
Connect Systems
