Old 12-29-2017, 5:11 PM
Default Anytone AT-D868UV not displaying contacts
The AT-D868 is not displaying contacts that have been loaded in the Digital Contact List.
I have tried formatting and importing contacts downloaded from datadump.cgi; I have also erased all of these, reset the radio, and loaded only a couple of contacts I programmed directly from the CPS (This is CPS 1.20 and firmware 2.20). It displays the id number correctly, but none of the other info. This happens whether the digital monitor is on or not. It receives the audio just fine, and displays the correct contact number, but none of the info. This is also true whether the subchannel is turned off or on.
Also, yes, I have checked the box to download the contacts in the CPS.
Have I forgotten some checkbox somewhere?
Old 12-29-2017, 8:09 PM
mcscanner's Avatar
It seems like you have taken all the correct steps. My 868 shows complete contact information but not all the time. Possibly because at this time I have only loaded TX contacts. Another possibly is Iím sitting on a channel that because digital monitoring is on and the QSO is on another TG it displays the channel information instead of the contact information. Only a theory at this point. I noted contact information was not always displayed but chalked it up to incomplete data set.
The road goes on forever and the party never ends...
Old 12-29-2017, 9:02 PM
Thanks for your reply.
I have only Group Call TGs in the "Talk Groups" section, and only private call DMR IDs in the "Digital Contact" List.
I am getting the correct talkgroup id displayed, and the DMR ID does display at the top, but the part of the screen where caller information should be is blank. It seems to me this has actually worked on a few occasions, but these were random events that I cannot duplicate no matter what settings I use.
Old 12-29-2017, 9:24 PM
I have suffering the same problem. After playing around with settings, I found turning on digital monitor on, under digital fun of optional setting, well to single slot. (not sure what the difference between single slot and double slot).
Hope this helps
Old 12-31-2017, 9:18 AM
mcscanner's Avatar
Sometimes I get the full contact information taking up all the screen top to bottom and other times just the operators name at the bottom. I'm thinking first time ID# seen full screen then just name on 2nd and beyond.
Last Talk group and User display is random too.
More work on the firmware which has come a long way from when I first got the radio is still needed.
868 hears my CS580 on simplex no problem. CS580 does not hear the 868. At this point as others have used simplex with a small sample of radios, but not the CS580 I think the issue is with the CS580.
P.S. Anyone have an idea of what Anytone calls 'talk permit' so you know the repeater heard you and the time slot is clear to start talking?
Old 01-01-2018, 12:33 PM
I noticed last night while listening to a repeater that, for about half a second, I got the full display on a couple of calls, but it quickly reverted to what I normally get, which is the caller id at the top, blank, and then the TG at the bottom. Gotta be a software glitch somewhere.
As far as "talk permit" is concerned, it appears to be automatic and not toggle-able. I tried connecting to a repeater I know is out of range, and after three seconds, I got a beep and a "Repeater not found" warning box. No idea how to alter the wait time or turn it off/on.
Old 01-02-2018, 11:19 AM
mcscanner's Avatar
Doc,
Have you been keeping up with the updates? Now at CPS1.21 & FW2.21, but I don't see anything about changes to contact display.
Repeater not found is not in the Alert tab so not likely to be modified. To me "Talk Permit" is the beep just after keying my radio when the repeater recognizes me and I get the beep to go ahead and start talking. Something I have seen on my other DMR radios but not this one. Admittedly not played with the alert tones to see if it is named different.
Old 01-02-2018, 3:27 PM
Definitely. New features all the time, but no improvement in the call data display at all.
Old 01-10-2018, 9:23 AM
mcscanner's Avatar
Doc,
A couple of days ago Contact Manager v2.46 was released allowing access and update to the 868 codeplug. Grabbed the latest user database from DMR-MARC (80,000). Pushed it into the codeplug and loaded it to the radio.
My impression is contact information is more consistently displayed than when I only had the TX population in the radio.
I'm not sure if selecting the channel that Bandmister net was on helped. Usually I just park the channel select on the 1st talk group for that repeater and let the digital monitor do the work. Once I saw a net was up I moved over to the 9000 talk group which is the TX link to Bandmister.
mike
Old 01-10-2018, 5:17 PM
Yes, I tried Contact Manager 2.46.
I have tried both manually importing datadump.cgi, and also via Contact Manager.
Still no luck with displaying private call data. Not sure what is left to try at this point.
Old 01-12-2018, 4:07 PM
Default Reply to simplex issue
I have the CS 580 and the D868 too and had this same problem with simplex. I found that when setting up a simplex channel in the CPS DO NOT CHECK the simplex TDMA box. Leave it unchecked. This allows full interoperability on simplex between the CS580, the D868, an MD-380 and a CS710.
Rick - KR3LC
QUOTE=mcscanner;2861124]Sometimes I get the full contact information taking up all the screen top to bottom and other times just the operators name at the bottom. I'm thinking first time ID# seen full screen then just name on 2nd and beyond.
P.S. Anyone have an idea of what Anytone calls 'talk permit' so you know the repeater heard you and the time slot is clear to start talking?[/QUOTE]
Old 01-12-2018, 5:28 PM
V-17's Avatar
Optional settings /alert tone tab / call tone. choices are: digital, analog, both, or none. It will give you a short beep about a sec after you key if your hitting the repeater.
K9OHV
Old 01-13-2018, 10:36 AM
mcscanner's Avatar
Rick, KR3LC
With another report of simplex working across radios I broke out the CS750 which I had reboxed ready to sell. It seems that the CS580 will not pass audio on simplex receive, but does indicate a received signal via the signal strength indicator. Firmware is 1.1.0. It does pass audio in monitor mode and display the correct CC, TG.
K9OHV,
Thanks for the heads up on the 'call tone'. Once you get use to hearing it on other radios it becomes a 'must have'. :-)
Old 01-30-2018, 9:16 PM
mcscanner's Avatar
In the previous post I commented the CS580 will not pass audio in simplex with my D868.
I have only one DMR ID# which I used in both radio. The source of my problem is the CS580 when the other radio has the same ID#. The D868 does not care.
It was easy to assign a different ID# in the D868 for only the simplex channels. Once that was done the CS580 passed audio without issues.
Old 01-31-2018, 4:31 PM
chief21's Avatar
If I recall correctly, the "Call Tone" is what AnyTone calls the typical Talk Permit Tone. Look for it in the ALERTS menu.
John AC4JK
Tags
anytone, at-d868uv, contacts
