Old 01-12-2018, 8:24 AM
Default Anytone AT-D868UV - Digital Monitor not working
Hi, My digital Monitor does not seem to be working, I am on FW 2.21 but when I go to channel/freq and enable Digital Monitor i can see the TG and Radio ID showing on screen but I hear no audio, every now and again I will get some audio.
I have some videos of the issue : https://www.youtube.com/watch?v=8Oh_bqzeUvc | https://www.youtube.com/watch?v=5QPyT3bOPR0 | https://www.youtube.com/watch?v=4BB6MXiySQk and https://www.youtube.com/watch?v=U4q2UAT1fvU
You can ever so slightly hear a slight hum when they Radio ID shows up.
Any ideas ?
Old 01-13-2018, 9:18 AM
In the CPS General Setting item, "Group Call Match" and "Private Call Match" should be un-checked. Also, for the channel, try setting both "Admit criteria" and "In Call Criteria" to Always. Also make sure "Privacy" is set to Off, and DCDM Switch should be Off.
Old 01-13-2018, 9:26 AM
Default ?
I don't see any of those settings in the CPS ? I am using CPS v1.21
Old 01-13-2018, 10:18 AM
mcscanner's Avatar
I with grahampaull on this as I don't see those items in CPS 1.21.
grahampaull, find a net that has traffic and see what you think. They were talking about the fact the 868 does not pass 'kurchuncks'. I'm thinking that with digital monitor on it is reporting the various channel info without any audio to pass.
mike
The road goes on forever and the party never ends...
Old 01-13-2018, 10:26 AM
Mike, I'm not 100%sure what you mean. I think you mean that the radio is picking up on digital data but that data has no audio to pass?
If I put this radio beside my GD-77 on the same frequency I get audio from the GD-77 but not the 868 in Digital Monitor mode.
If I program a channel in with the correct TGs,CC, Slot etc the audio comes through fine. It's only in Digital Monitor mode that I have the issue.
Sent from my SM-G950F using Tapatalk
Old 01-13-2018, 10:39 AM
mcscanner's Avatar
Yes that is what I meant.
I'm thinking maybe digital monitor processing time impacts received audio based on your information about using a correctly programmed channel.
Seem like a reasonable conclusions.
Old 01-13-2018, 10:50 AM
Yeah, and it seems to be a hardware issue as I have tried all FWs from 2.18 up to 2.21 and they all do the same thing. Very frustrating.
Old 01-13-2018, 11:43 AM
Ooops, sorry, I brought up the CPS for a different radio. That's what I get for having all this stuff on the computer.
Under Optional Setting, Digital Function tab, make sure that Digital Monitor is set to "Double Slot", Digital Monitor CC and ID are both set to "Any".
As already mentioned, the radio does pass "kerchunks" in monitor mode; also note that Openspots, etc. pass "kerchunk" type signals when they attach and detach from TGs, and I do see those on the radio.
Also, did you do the BaseBand update? Could be related:
This updating is for resolving the issue.
If I am talking on time slot 1 and another person starts talking on time slot 2,
my receiver on time slot 1 will be muted while the other person is talking.
Old 01-13-2018, 12:02 PM
I checked the monitor settings and can confirm I have set 2 slots, CC and ID to any.
I don't the baseband provided by Connect Systems on the 21st December, is this the latest baseband update?
I think I need to learn a bit more what these "kerchunks" are lol.
Old 01-13-2018, 12:08 PM
Yes, this is the latest (only) baseband update I know about.
"Kerchunks" are signals that appear when someone briefly keys their radio without saying anything. However, if you are hearing audio on your GD-77 but not on the 868, it isn't a "kerchunk". Maybe there is still some bug in the firmware.
Old 01-13-2018, 1:13 PM
Yeah, this definitely isn't a Kerchunk. If you listen closely to the videos above you will hear a slight hum when someone keys the mic.
Yeah, I have the latest baseband installed. I think I will get this returned ASAP.
Old 01-14-2018, 6:29 AM
Another observation I have noticed is when it is sitting side by side with the GD-77 it will miss some calls even when the code plug has all the correct parameters like CC, TS and TGs, almost as if it is when someone replies to quick to a call it does not pick up the call.
I have asked the seller to exchange this so hopefully the replacement is better.
Old 01-14-2018, 9:03 AM
Strange, by and large I have had little trouble with the 868, but the GD-77 has been nothing but problems. If they don't get the software and firmware straightened out soon, it's going to wind up on ebay.
By the way, I noticed last night that the call detail display actually worked! But I was using the openSpot, not a repeater. I wonder if some of this may be due to repeater mis/dis configuration?
Tags
anytone at-d868uv
