Old 02-11-2018, 7:26 AM
Default Zastone ZT-9908 Programing Help
I have screen grabbed a few selections from the zastone programing software I am using and have a few things I am not sure about, I have highlighted the selection I need explaining as this software is the first I have had without a help file explaining all the selections, hope somebody that has played about with this can help as the radio itself seems quite good so far.
Old 02-14-2018, 5:34 AM
Default got some now thanks
STE sqeulch tail elimination (should have know that one
Wake Frame all to do with OACSU off air channel set up
Data Type for normal, trunking etc.
Area code another radio type ID for trunking type set up
Status info number also being looked into by others as no code template has been found so far?
Wired Copy though to be for messages from a base wired system (not required so I will leave closed)
