Old 02-12-2018, 3:08 PM
Default Antenna for Anytone 868
Anybody have a recommendation for a better antenna for an 868?
Old 02-12-2018, 4:08 PM
W2SJW's Avatar
Senior Member
If you want a compact antenna - https://powerwerx.com/tera-ant-54-co...l-band-antenna
If you want a full-length antenna - https://powerwerx.com/tera-ant50-dual-band-antenna
I use the ANT-54 on mine with no issues at all. These have thread protection all the way down the length of the center pin. This is a MAJOR consideration, as not all SMA-F antennas will fully protect the pin (and lead to all kinds of strange behavior due to RF ingress).
If you want a stubby for hotspot usage, this is also great - https://www.amazon.com/Retech-RHA-60...ct_top?ie=UTF8
Scott
NJ & PA DB Admin | NJ Forum Moderator
My Sentinel Favorite Lists
Old 02-12-2018, 8:39 PM
Thanks a bunch. Is the antenna you’re using a big improvement over the factory unit?
Old 02-13-2018, 7:06 AM
W2SJW's Avatar
Senior Member
It's not meant to be an improvement, it's made to take up less space.
I use the 868 as a backup to my 7550e on my hotspot, and my county public safety is all on VHF analog repeaters. It works perfectly for what it's intended for (basically, a nightstand radio & fairly unobtrusive to the eye with the smaller antenna).
Scott
Old 02-14-2018, 10:26 PM
Would a mag mount on the roof of my vehicle make a difference in reception and if so what should a guy look at?
Old 02-15-2018, 10:58 AM
ke6gcv's Avatar
~~ DELETED ~~
Last edited by ke6gcv; 02-15-2018 at 11:01 AM.. Reason: Found the answer to my question!
Old 02-15-2018, 11:02 AM
W2SJW's Avatar
Senior Member
There are 100x more available choices for a standard SMA, you just need to look around a bit on eBay and Amazon.
For the OP - yes, a mag mount on the roof will be heads-above the rubber duck in performance, but you also need an appropriate adapter. Don't cheap out on that part of the project.
Scott
Old 02-15-2018, 11:04 AM
any chance you can point me in the right direction as far as adapters and antenna go?
Old 02-15-2018, 11:06 AM
W2SJW's Avatar
Senior Member
I can't be any help on the adapter, but my favorite antenna hands-down is the Diamond NR-770HA.
It doesn't require a ground plane at all, so would work pretty good on a large mag mount.
Scott
Old 07-06-2018, 3:39 AM
sounds like that the Diamond NR-770 antenna is the BEST ? 73
Old 07-06-2018, 7:12 AM
chief21's Avatar
Caution - Be aware that the Anytone radio is likely to be much more susceptible to low-level or out-of-band interference when connected to an external antenna. You might want to borrow an antenna and try it before committing to a purchase.
- John AC4JK
