My review of the rd-5r
riccom
Ok where do I start, as a starter of this dmr world, let me say it is a bit of a learning process, how to enter slots, uid, color codes, and tg aka and listening to a digital voice, and not analog, and the quality of this radio is a lot better then I expected.
The look and feel:
Well it is like any other uv family radio, as in cosmetics and feel, the antenna is better built then the normal baofeng antenna, (it is a radioditty rd-701 antenna), and the signal, is ok, at least no front end issues, (thank god, I live near major radios towers).
The display is nice but I wish it would be color changing if not on the led , but on the screen it is crisp, but the white leds are Diffrent then what I am used to, but it is a ok thing I guess.
The meat and potatoes of the setup and operation of the radio, it is simple if you know a dmr code plug, if not, do the homework , it will help, the basic is ok, but I myself, have a lot more to learn, and looking at the threads on here,
The operation of the radio, is good, I have a few dmr channels on here listening and comparing to my scanner, it is night and day, no static, and on a 40 watt system I can get good signal at 25 miles away,.
I do like the front panel programming, but I have yet learn how to save it, to the main scanning banks on it. Maybe some one knows how to,
I am still learning this thing out, but from what I can tell, it is awesome.
riccom
I did make my own code plug, I used an old one from a web site to use as an example to go by, and I get amr ambulance and it is encrypted I know but as a test on what I could do, then used the Nucor system and get them in the clear, and if and when I do some traveling I know how to enter them
riccom
(in a robert stack voice) UPDATE, since the new firmware is not working it seems to be an analog issue with the rd-5r, now the new radio i have is doing the same thing with the beta, now i do have the digital side working and the older one is still having issues not keeping up with the dmr decoding, , now i know it is a beta but i will put in some input on this
jaspence
Michigan
Thank you for the review. I hope this radio does not inherit the issues present in the radio this is based on, the Radioddity GD-77.
https://forums.radioreference.com/b...356586-radioddity-gd-77-a-10.html#post2913445
I have had no trouble with the GD-77 and 3.1.1. One thing I do, which does take time, is to build every code plug from a clean database, including the talk groups and individual receive groups. I have 8 different radios, and it is not just the GD-77 that requires individual receive entries.
riccom
ok here we go, turns out they sent me another radio, this time the new update killed the analog side of the new and older radio, seems that radioditty has a big issue on there hand, and if they wont fix it soon, then we may need to have a pow wow with them to get this issue fixed, this will cost us and the sellers money!
mikew66
Cuyahoga Falls, Ohio
I returned mine and bought an AnyTone D868UV. Very easy to program, great customer service, and I found a lot of code plugs for it for my area.
Sent from my SM-G950U using Tapatalk
usswood
Terre Haute, IN
After some programming errors on my part, I LOVE my RD-5R!!! Strong transmit signal and great range for this little piece of equipment... I to had issues getting to digital side to transmit correct, but after a few tweaks of the setup, I couldn't be more happier with this model!
Vols970
Could someone be some assistance to me on helping me program the rd 5r? I got the new software and it seems to have a virus or something. Each time i try to program it , the radio is harder to operate. Ive managed to get some freqs in but it will not scan. Any advice would be appreciated
usswood
Terre Haute, IN
I could send you a code plug, but it is setup for Hoosier DMR and sites close to Indiana... Don't know how useful it would be for ur area?
kn4int
Webster, KY
I would be interested. The code plug I used for my TYT-380 came from Hoosier DMR, but I don't see a spot in the codeplug vault for a RD-5R plug
73 de KN4INT
rgchristy
Delco, PA
Is it possible to program, even if for receive only, frequencies between 500 & 512 MHz. I've looked at the CPS and it appears so, but I was wondering if someone could please try it on an actual radio.
Thanks.
