Old 07-12-2018, 11:31 AM
Default How to turn off "transmit" using Chirp with NOAA pre-programmed channels
Hello. That is basically my question.
In Chirp, the offset is set to 0.000000 for these NOAA channels, and there is an error message that I get if I try to set the offset to some "out of. radio range" number. There is no "transmit frequency" column in Chirp (late June version), so I can't turn that "off." How do I assure that no accidental transmissions occur on these channels from a programming standpoint? I'm using a Baofeng radio. I am surprised this is not automatically programmed into the pre-programmed NOAA channels provided in Chirp.
I'm looking forward to your comments.
Old 07-12-2018, 11:36 AM
jonwienke's Avatar
Set Duplex to OFF.
Gone camping.
clbsquared's Avatar
You leave the transmit frequency block blank.
Old 07-12-2018, 11:48 AM
jonwienke's Avatar
CHIRP doesn't have a transmit frequency block. It has a frequency column, and a separate offset column. If you want to disable transmit, you set the Duplex column to OFF.
Gone camping.
Old 07-12-2018, 12:09 PM
Thank you. That worked, jonwienke.
I appreciate the help.
Sincerely,
Pamela
Old 07-12-2018, 12:48 PM
jonwienke's Avatar
You're welcome.
Gone camping.
Tags
chirp no transmissions
