I have a Uniden BCT7, that had a highway patrol proximity warning system, known as "BearTracker." The system worked by tuning into the highway patrol frequency of a particular state that was used as the mobile extender channel.
When a highway patrol officer got out of the police car (or sometimes while parked on the side of the highway/freeway), the officer would activate the mobile extender to allow his or her handheld radio to communicate with the car radio. The handheld radio is on a different frequency than the car radio. Being this mobile extender used less power than the main car radio, hearing the transmission usually means that you are within close proximity of that transmission (normally less than 3 miles).
So when the radio receives a transmission from this preprogrammed frequency, it would set off an audible alert (alarm) and immediately tune to that frequency.
I no long use my BCT7, so here is what I did on my Uniden BCD396T. For all my CHP groups, I also have the CHP mobile extender frequency (154.905 MHz) as a non-assigned channel. I have three of them, being CHP uses different CTCSS tones for each, one for car2car, car2station, and mobile2mobile, and have ID'd them as such. I assigned a separate alert tone for each type and set them as a "priority" channel.
This accomplishes the same results as Uniden's BearTracker feature.
I took this one step further. Not only did I program the base (output) for each CHP channel, but I also programmed the mobile (input) for each CHP channel. Being input transmissions are coming from the car's relatively low-powered radio and not from a high-powered mountaintop, tower, or rooftop repeater, I know I am in close proximity of that transmission. I take into consideration the quality of the transmission (static, etc.) and the meter on the radio to determine about how far the transmission is from me. The clearer the transmission gets, the closer I am getting.
This concept holds true with other agencies that use the base/mobile model, like CHP, or the semi-duplex model like LAPD or LASO.
One drawback to this whole thing for me is that sometimes in the Los Angeles Metro area (SoCal), you are usually within 3 or so miles from one or more freeways, and usually within 5 or so miles from a CHP unit. Hearing a transmission on a mobile extender could be literally two freeways over.
