Try switching to Open mode and see if it helps.
Press FUNC + 5 (or FUNC + 0 ... I can't remember) to switch between Open and Closed mode.
Has anything changed (programming wise) since the scanner was last working?
It's possible a channel has been locked out or the mode changed. If your able to upload the data file here and it can be looked at for any errors.
Other thing to consider: The Pro-96 does not automatically handle EDACS patches, so if Cabazon and Temecula are patched, you won't hear anything unless you have the patch id programmed in. (usually 2045, 2046, or 2047). Running in Open Mode (for testing) will pick these up.
