Go Back   The RadioReference.com Forums > Regional Radio Discussion Forums > California Radio Discussion Forum
California Radio Discussion Forum Forum for discussing Radio Information in the State of California.
Old 09-18-2009, 02:11 PM
k6scm's Avatar
Question V-Tac, U-Tac, I-Tac Frequencies... UTac21?
My current understanding of the V, U & ITac nationwide common/interoperability frequency assignments is as follows:
V-Call 155.7525
V-Tac 1 151.1375
V-Tac 2 154.4525
V-Tac 3 158.7375
V-Tac 4 159.4725
U-Call 453.2125 (458.2125)
U-Tac 1 453.4625 (458.4625)
U-Tac 2 453.7125 (458.7125)
U-Tac 3 453.8625 (458.8625)
ITAC channels. All the below use a PL of 156.7 Hz nationwide & and are pre-"re-banding."
I-Call 866.0125 (821.0125)
ITAC 1 866.5125 (821.5125)
ITAC 2 867.0125 (822.0125)
ITAC 3 867.5125 (822.5125)
ITAC 4 868.0125 (823.0125)
Yesterday, I observed some interesting radio traffic from a local No. Cal law enforcement agency in my area. Basically, a 'county' IT support tech was in the process of assisting in the setting up of a dispatcher's console desktop while communicating with the dispatch office from separate mobile unit, in two-way communication with the dispatcher on a secondary frequency of the agency. The tech was instructing the dispatcher on how to select & assign to the Motorola Centracom desktop console used by the dispatch, an icon for a specific channelization selection assignment for "UTac Twenty-One."
I am unable to locate any reference to a "UTac21," much less any FCC listings or usage anywhere near my location, or elsewhere. It doesn't appear in the UTac frequency table under the Common/Shared group, nor in the FCC Database under PW - Public Safety Pool, Conventional. Does anyone recognize this, or have familiarity or similar reference point for/with UTac 21?
Old 09-18-2009, 03:10 PM
The following link may be of some help. The newer naming convention begins on page 4 with a table on page 7.
http://www.oes.ca.gov/WebPage/oeswebsite.nsf/PDF/National%20Public%20Safety%20Telecommunications%20 Council%27s%20Channel%20Naming%20Report/$file/NPSTC%20Channel%20Naming%20Report.pdf
Old 09-18-2009, 03:11 PM
Default UTAC channels
I can only locate three UTAC channels:
UTAC41 National Interop Tac 453.4625 156.7 458.4625 156.7
UTAC42 National Interop Tac 453.7125 156.7 458.7125 156.7
UTAC43 National Interop Tac 453.8625 156.7 458.8625 156.7
I'll keep looking for a UTAC21 and post it if I do.
Old 09-18-2009, 04:54 PM
I had a problem with the link, but here is an appendix from the December 2007 California Statewide Communications Interoperability Plan. The only 21 channel in the NCC/NPSTC linup is "VFire21."
Old 09-19-2009, 02:35 AM
ColoradoRedlands's Avatar
Send a message via AIM to ColoradoRedlands
Note that the 800Mhz freqs in this book are the "Re-banded" freqs. Here in Colorado we are completely rebanded in 800, so we use those in the book.
California will still be using the 860mhz ITACS until the various systems go thru your eventual rebanding.
Old 09-19-2009, 01:43 PM
Here is a reference that might be helpful:
http://www.npstc.org/documents/NIFOG...04-14-2008.pdf
Note that the channel numbering is such that a given channel number is not repeated. Thus all the 40 series are UHF, etc.
Hope this helps.
Old 09-19-2009, 02:25 PM
ecps92's Avatar
Send a message via AIM to ecps92 Send a message via Yahoo to ecps92
Here it the NEW Version [errors in Ver 1.2]
http://www.npstc.org/documents/NIFOG_1_3.pdf
Hope this helps.
Bill Dunn N1KUG
Cruise Ship Frequencies
http://www.scanmaritime.com
Feeding USCG Sector Boston at
http://www.scannewengland.net/index....geid=nesflogon
Old 09-20-2009, 12:01 AM
k6scm's Avatar
Excellent post. Thanks!
Old 09-20-2009, 12:09 AM
k6scm's Avatar
Thumbs up
Thanks to all of you who posted replies for your input. Great info! I still believe it was a UTAC "two-one" I heard and not a "four-one" that was being discussed at the time. Who knows though, as my ears are aging... Hi Hi. I might of had it wrong.
The same agency was really busy with a major drill exercise with units afield and that engaged a mobile command unit, the radio operator of which was going down "the list" and conducting radio checks on CLERS, CLEMARS, CSERS with both the agency and CALEMA at the same time. I believe they had trouble with the mobile units radio check to the dispatch on the UTAC and that is what they were trying to resolve.
Old 09-20-2009, 09:05 AM
ecps92's Avatar
Many Agencies have the ability to PATCH the 3 TAC channels.
V to U to 800 for a Tri-Band Rptr network
Bill Dunn N1KUG
Old 09-20-2009, 10:36 AM
Thanks ecps, I have V1.3 saved to my desktop files and a hard copy in my field notebook but could not find the link to it. Here on my laptop I only have V1.2, so my foggy memory led me to believe it was the current version.
I'm glad we have so many knowledgeable people here so we get the information correct.
Old 09-20-2009, 11:55 AM
We have all of that on a handy Wiki page too. Common Public Safety - The RadioReference Wiki
Tom
Old 09-20-2009, 02:45 PM
I can't find my source material right now but there are new medical channels beyond the long time standard 10, numbered 12, 22, 32, 42, 52, 62, 72, 82, 92 and 102. They are narrow band pairs in the 462/467 and 463/468 range, just like the original 10. I may have found them in the FCC regs that were updated to reflect the new 700 MHz band and narrow banding. This is somewhat difficult to find but should be known by those who hunt and peck for such things.
I have one scan list common to all my PSR-600 files that I call the "Interoperability" list which I keep in the radio's list 20. I've written all the fed and non-fed frequencies, the med channels, and some other frequencies I've picked up here and there such as the federal law enforcement nationwide common. I have a large fire list which I keep in' the radio's list 19. That way I can listen to different types of large incidents, no matter what type, and not be frantically trying to program from a list that probably won't be in the car at the time.
Old 09-20-2009, 05:20 PM
Here you go. The med channel numbers are on page 269 of
http://edocket.access.gpo.gov/cfr_20...47cfr90.20.pdf
Tom
Old 09-21-2009, 09:08 AM
ecps92's Avatar
It's called Team Work and Share the knowledge. WE can't remember it all, plus there is so much of a difference east/west of the Mississippi !
Bill Dunn N1KUG
Tags
california, common, interoperability, shared, utac
