| California Radio Discussion Forum Forum for discussing Radio Information in the State of California. |
02-16-2013, 11:57 PM
Ahh, remember the good ole days when CHP had to pace or catch you with the plane? Good times.
02-17-2013, 10:48 PM
CHP Air Speed Enforcement
Originally Posted by stingray327
What happened to the speed enforcement via airplane? I used to hear them but now I hardly ever hear them.
There was an air unit in the Tracy area this past week for two days working 580 between 132 and 205 one day then working I-5 from 580 to 120 the next day. They worked on Blue and from where I was I could hear both the air unit and the ground units talking to each other. But that was the first time I've heard them in this area doing air enforcement since I moved back to California two years ago. So definitely not occurring (near me anyway) as often as it used to.
I do hear CHP's 'air 21', a rotary wing unit, in the area quite often, but always in a support role to some kind of in progress type incident to different agencies. They will usually first be heard contacting the local area CHP dispatch to advise them that they are in the dispatcher's area, and what agency they are assisting as well as what frequency they will be on and in what general location they are helping out at.
02-18-2013, 3:43 AM
CA/NV/KS/NE DB Admin
Just a minor correction: Air 21 is a Cessna fixed-wing (airplane). H-20 and H-24 are Valley Division's rotary-wing (helicopter) units.
David
Dominus pascit me
"Don't take life so seriously; no one gets out alive anyway!"
02-18-2013, 12:51 PM
I've heard a lot of Air-21 and H-20 down here around Sac lately. Air-21's been refueling at McClellan and H-20's been up in the late afternoons. I travel 80 east quite a bit and haven't seen much speed enforcement around Placer Hills Rd like there used to be. I liked pulling off there and parking up by the big rigs and just watch the ground units pick people off with the help of the fixed wing. Nothing the last several months.
Pro-82 / Pro-97 / Pro-162 / SC230 / BC346XT
02-18-2013, 7:20 PM
Maybe with things settling financially (long shot I know) here in Cali things will start to change and pick up for the better for the scanner enthusiasts.
02-19-2013, 2:00 AM
It would not surprise me one bit if money is a factor.
Flights crews trimmed back, flight time limited, and fewer "speed enforcement grants" - Yes, there are grants specifically designed to fund overtime and resources for traffic enforcement.
Also - a lot of local law enforcement air units have been either trimmed back or grounded. I know that in the Sacramento area, this has caused local law to seek CHP (state) air support more often.
02-19-2013, 11:56 PM
The cars are low powered transmissions aren't they? I can hear the cars alot in other counties which is strange but the air enforcement ground units are always weaker in signal strength. The plane also but line of sight may play alot in this. Signals fade in and out.
The distance here is about 15 miles.
02-20-2013, 12:01 AM
Listening to CHP in the Stockton area on 44.92 about 2 weeks ago or so I could hear the AIR unit pointing out cars and their types that were good for a stop. I couldn't hear the units response to it, they must have been on the BLUE possibly? It was interesting though because Base would continue to carry on default dispatch duties while the AIR unit would butt in between transmissions while doing their detail. Might of been patched in possibly? My only guess to that detail would be the speed enforcement that you mentioned.
44.92 I will have to plug that channel in or check to see if it is already in as I don't recall picking up anything if I have that programmed in.
02-20-2013, 1:13 AM
CHP
As many of you know, I concentrate heavily on monitoring CHP. I monitor base, mobile and extender frequencies and use antennas that give me good signals on low band.
I hear them doing speed enforcement all the time on the I80 corridor by the Antelope scales. This past (3 day) weekend I heard them on BLUE2 doing enforcement on Highway 50 between Sunrise, Hazel & Folsom Blvds. Some of the speeds they clock on that stretch amaze me.
Of course I was just listening to a high speed chase on Turquoise that moved to Black at speeds of 110+. It turned out to be a parolee at large and they only caught him after using a spike strip.
PRO-95 | PRO-10 | PRO-97 | PRO-77 | PRO-92 | PSR-300 | PSR-310
02-20-2013, 1:18 AM
Yes I do hear alot of these happening. Usually ends with a crash then a foot bail unless CHP deems it too dangerous to continue chase.
02-20-2013, 6:46 AM
Bit off from the speed trap discussion, but where is the Blue's antenna located? I know the Stockton Dispatch center has their radio tower right next to the Office and repeats up to the mountain units. After yesterdays fiasco up on the "hill" from the snow, Stockton moved all Stockton and Tracy units to the BLUE while Amador and Calaveras stayed on the White. I programmed in the BLUE base frequency and would only get static que ups but never any audio.
I also get all the Stockton and Tracy unit traffic fine both directions but any transmissions to Amador or Calaveras units I only get either the unit or Dispatch, it alternates.
02-20-2013, 2:32 PM
BLUE2
I am fairly certain that the speed control communcation I've been monitoring on BLUE2 are in "car to car" mode on the base frequency. That means no repeater or tower involved.
02-20-2013, 8:22 PM
You should check if you have blue2 program not the old blue1. And remember they use car to car when they do speed traps so you must be near them to hear them
The dispatcher might be transmitting on sites you cant pick up
And yesterday was the first time I heard Coastal blue2 for Santa Cruz units on high way 17
still a noob in scanners
02-20-2013, 9:46 PM
Originally Posted by tahoekid77
Are you still using the BlackVue DR400G-HD ? Hows that holding up?
02-20-2013, 11:47 PM
44.84 BLUE 2 is what I have programmed in. I got static que ups but no audio. Interesting thing, today was the first time I have seen a "Silver Alert" on the CHP CAD website. Missing 89 year old from Citrus Heights. Last seen 3:45am Wednesday morning.
Sacto 9-1-1: CHP issues 'Silver Alert' for missing Citrus Heights woman
02-20-2013, 11:56 PM
Thanks for those vids Tahoekid. Was the beeping sound in the second video alerting to radar or a police radio signal? Out of all the LE i'd risk playing "chicken" with (minding my own business) CHP always freaks me out. Never know about them.
02-21-2013, 12:05 AM
Beep sound is Escort Redline radar detector. If you notice there are 3 other CHP cars in the video, one making a stop, one on the off ramp turning around. There were 4 in total - Memorial Day weekend - always an excuse to give out more tickets. (Much needed revenue).
02-21-2013, 12:07 AM
BlackVue works great. I noticed the price went up on those by almost $100. I can record 9 hours of HD video on a single 32 GB microSD card at 30 fps, or of course double that at 15 fps.
02-21-2013, 12:12 AM
They use very low power from the aircraft, probably 1 or 2 watts since they only need to go less than a mile unobstructed air-to-ground. I got them a few weeks ago again in SAC, and I was only able to hear crisp signal when I was within 2 miles of the kill zone.
For an interesting look from their perspective, watch this video - and note the data presented on their display.
This is the same stretch in my video where I was following the cop. Sacramento, I-80 at Greenback Lane, right at the beginning of this video.
Tyreke Evans Speeding Police Video - YouTube
-- After listening to this again, I'm pretty sure the guy on the radio is the same guy I hear every time. (Maybe he's seen my videos)
Reason: typos
