Go Back   The RadioReference.com Forums > U.S. Regional Radio Discussion Forums > California Radio Discussion Forum
California Radio Discussion Forum - Forum for discussing Radio Information in the State of California.
Old 05-05-2013, 11:27 PM
Default Cal Fire Tac 12 Data Channel??
So, I have what is listed as Cal Fire Tac 12 154.46375 programmed into my scanner. From the Fresno area, this channel just emits garbled data type noise. When I did a state wide search with that frequency, nothing popped up, not even Cal Fire. Any ideas?
Old 05-05-2013, 11:36 PM
I just went back and looked and that is not Cal Fire Tac 12, in fact half of my Tac channels were not right, but still, anyone have an idea what this noise is and who it belongs to?
Old 05-05-2013, 11:52 PM
kma371's Avatar
Global DB Admin
Default Re: Cal Fire Tac 12 Data Channel??
likely telemetry ?
have you tried to FCCsearch it?
Old 05-06-2013, 12:06 AM
W8RMH's Avatar
That is a SCADA frequency.
Licensees - SOUTHERN CALIFORNIA EDISON COMPANY, SACRAMENTO MUNICIPAL UTILITY DISTRICT, CENTERVILLE COMMUNITY SEVICES DISTRICT
The database shows CDF Tac 12 as 151.46000.
SKYWARN SPOTTER Unication G4 Home Patrol 2 BCD996XT BR330T
Old 05-06-2013, 12:31 AM
Thanks, it is most likely SCE. I had never even heard of SCADA until tonight. I did fix all of my Cal Fire Tac channels, like 12 of them were wrong or old frequencies. Again, thanks for the help guys.
Old 05-08-2013, 1:13 AM
It may or may not work but try adding tone protection to the CAL FIRE tac's. It's tone 192.8 on all of them. That might alleviate some of that noise.
Old 05-08-2013, 7:38 AM
inigo88's Avatar
California DB Admin
SCADA is pretty neat stuff. It can be used for everything from fire station alerting to utility telemetry, and a lot more.
Old 05-13-2013, 10:35 PM
CalFire doesn't use data/SCADA for station alerting. Everything is done over the air by voice, but some Schedule A operations have a wireline Rip-and-Run system as a secondary system. Several cities are using a station alerting system by Zetron which is either wireline, OTA, or both.
Command 7/Tac 12/MMU Local is 151.460.
Not all units are using tone protection on their tac channels. Currently, only the Air-to-Ground channels are required to have tone protection, and it will be either Tones 1, 2, or 3; with ground units having TX PL and air units having RX PL. This was done this year to eliminate interference between incidents.
John "Smokey Behr" Gleichweit
FF1/EMT, CCNA, MCSE
N6FOG - WQYV603
CalEMA 51-504
Old 05-13-2013, 11:42 PM
RRU is. Battalion 12 is currently testing the data portion of the Riverside county PSEC radio system which includes station alerting, MDC and print out functions. If the beta is successful, it will be rolled out to the entire unit in the coming weeks.
Old 05-14-2013, 1:32 AM
norcalscan's Avatar
John, all CALFIRE tacs last year went full tone protection statewide. Tone 16 192.8 for encode and decode. It is an exception per incident to turn tone protection/code guard off and that is for responses that have mutual aid agencies responding that still havent reprogrammed their radios, this creating a life-safety hazard and requires every responding resource to confirm that tone protection is turned off, much like powerlines down.
This year also starts tone protection on vfire freqs of tone 6, (156.7) and transitioning calcord over to tone 6 with tx encode of tone 6, in prep for full tone protection next year.
Old 05-14-2013, 11:42 AM
mark5388916's Avatar
With a roll out of tone protection on the Mutual Aid Frequencies, do you know if a new Cal-Ifog is in the works?
Old 05-14-2013, 10:37 PM
Hi, is vfire 156.7 tone on both tx and rx ?
And calcord is generally simplex so 156.7 on both tx and rx ? Just clarifying ....
You be steppin....I be stomping.
Old 05-14-2013, 11:56 PM
yes, 156.7 on both sides for VFIRE, and only tx side for CALCORD
Old 05-15-2013, 2:15 AM
norcalscan's Avatar
Agreed. Full tx rx tone 156.7 protection on vfire channels, and only tx 156.7 on calcord. Next year the rx protection for calcord should kick in.
