Go Back   The RadioReference.com Forums > Topic Specific Forums > CB Radio Forum
CB Radio Forum Discussions regarding Citizens Band Radio (CB)
Old 04-13-2009, 04:55 PM
CLynch7's Avatar
Default Old 23 channel base
I found an old base station, a GM 23B, and was wondering if it was still viable, and legal. I'd heard 23 channel units aren't anymore. And yes, I'm studying for my Tech license, so this isn't going to be my only radio use.
Old 04-13-2009, 05:07 PM
It would be illegal for a retailer to sell it as new.
I would have to go digging in Part 95 to be sure, but I suspect it is legal to use.
Worth the trouble when you can use a modern mobile with a power supply? Probably not.
Some posts can be interpreted in various ways.
Mine generally mean exactly what they say.
Old 04-13-2009, 06:06 PM
trace1's Avatar
Your "old" GM 23B should still be legal since no license is required for CB use and as long as it is/was FCC certified. It is probably still viable too and while 40 channels units are being sold now, if the old still works why not use it for just a little fun and nostalgia.
And good luck on your Tech license so you'll need another radio for that use anyway...
Cha bhi fios aire math an tobair gus an tràigh e.
Old 04-14-2009, 01:10 AM
CLynch7's Avatar
It's certified, running all 4 watts. Got to find an antenna. Not much cb traffic around here, maybe I can stir some up, especially being 6 miles from a major freeway.
Old 04-14-2009, 07:40 AM
You can sell the microphone and give the radio away for free...
wesct
Crime doesnt pay because radio waves are faster than cars!
Old 04-17-2009, 11:55 AM
Default 23 Channel Unit
If you have a working older unit, good for you. I have a working 23 channel mobile unit. I have used it in conjunction with 40 channel units. (The only problems are 1. The obvious frequency limitations, and 2. I have more transceivers than I do antennas.) Anyways, they're still usable, so why not hold on to them ?
APTN
Old 04-17-2009, 03:54 PM
cqcqcq's Avatar
USE it have fun, 4 watts not many around like that.
cqcqcq
Old 04-20-2009, 11:16 AM
CLynch7's Avatar
It is more of a new project now. It receives quite well, but doesn't seem to transmit. The meter will move when TX, but after releasing the mic button, it squeals for a few seconds, and then goes back to normal. Best antenna I could come up with is a car mag mount, and while I've got a large cast iron firepit in the backyard, it's on a deck, and not exactly a good ground. I did take it apart, and it is a Uniden in disguise.
Any repair ideas?
Old 04-21-2009, 09:38 PM
CLynch7's Avatar
Needed grounding. Works like a champ!
Similar Threads
WTB an Older 10 to 20 Channel Base Scanner peterjmag Old Classifieds Archives 0 10-26-2008 11:11 PM
Help with railroad frequencies. KC0QR Nebraska Radio Discussion Forum 14 05-21-2008 07:10 PM
FA : Radio Shack Pro-2042 1000 channel base scanner dconti Old Classifieds Archives 0 07-26-2007 09:25 PM
Trains CLB South Carolina Radio Discussion Forum 4 05-13-2007 10:00 PM
Common Fed Freqs mike_s104 Federal Monitoring Forum 63 04-23-2007 11:39 AM
