Go Back   The RadioReference.com Forums > Topic Specific Forums > CB Radio Forum
CB Radio Forum Discussions regarding Citizens Band Radio (CB)
Old 05-16-2009, 08:22 AM
NYRHKY94's Avatar
Default Options for Powering Mobile CB In House
Hi Guys:
Looking for different options for powering up a mobile CB in the house. I know there are various AC to DC converters/adapters out there, but I figured the folks on this board would be able to provide me with a pretty good summary of what works well and what doesn't. It would be great if the adapter accepted a cigarete lighter power cord.
Thanks in advance!
Thanks - Mike
PSR-600, Pro-106, Pro-2096, Pro-96, Pro-2053, Pro-2052, BCD996T, BC796D, BC898T, BC370CRS, BC210XLT
Listen to my feeds at:
Radio Reference NH
Radio Reference NJ
Old 05-16-2009, 08:43 AM
davidmc36's Avatar
Some of the 12V regulated power supplys that you can get do have cigarette lighter receptacles along with the binding posts. I don't do CB but my Dad ran his for years with a 2 AMP power supply. He had no problems with it, no noise or any issues.
No Bounce, No Play.
The one who dies with the most toys wins!
Personal Weather Station
Old 05-16-2009, 09:16 AM
trace1's Avatar
You could use a gel cell battery, that way you'd still have power if your comercial power was out.
Cha bhi fios aire math an tobair gus an tràigh e.
Old 05-16-2009, 09:17 AM
If you use a power supply, don't forget the "breaker" good buddy
Psalm50:5, 110:4
Old 05-16-2009, 10:32 AM
Hello NYRHKY 94:
You came to the right place for good advice! I use to remove dear ol Dad's Truck Battery to run my Gonset G12 CB Tube Radio, and when he got up in the morning I had to get it in grear put in back in his truck with a charge so it would start for him to go to work in the mornings. Sometimes we had to push the truck down hill to get it started. Man did I ever love getting a 12 volt power supply, so did Dad!
I suggest a little Heavier Duty power supply than is needed as you have many radios there, and may need or want to run other stuff.
Pyramid 12 volt DC Power Supplies
I suggest a 10 Amp supply as some CB Radios put out more than expected, and this allow a lot of head room for other radios that run off 12 VDC.
I got tierd of not having enough amperage capacity so I bought a 35 and 70 amp power supplies. Happy radioing, Ten-4.
Jay in the Mojave
Old 05-18-2009, 12:30 PM
Default Mobile in Building
This is probably not the best setup but I used these two items to plug it into the wall.
http://www.radioshack.com/product/in...ductId=2102439
AC-DC Converter/ AC-DC Adapter/ AC-DC Power Supply (500 MA) [AC DC co
APTN
Old 05-18-2009, 01:04 PM
N_Jay's Avatar
Not for a CB, I hope?
Some posts can be interpreted as either humorous or insulting
When not sure, always assume humorous
If you only find it insulting you have misunderstood my post or I have misunderstood your post
Old 05-18-2009, 05:23 PM
davidmc36's Avatar
.5 amp seems pretty small to handle that. The 2amp that pops used seemed to handle a mobile fine, but .5
No Bounce, No Play.
Old 05-19-2009, 02:43 PM
Thumbs up What he said
2amp minimum (what size fuse is in your power cord? that would be a good indicator of what size you need). I use a 20amp for mine only because I got it cheap, but, if I were to buy a new one I would get something a little bigger than I needed just to be safe. I've heard of a 75% rule, that is, your power rating should be high enough so that your only using 75% of it. If your DC power supply is rate at 5amp, 5X75%=3.75amp, if your drawing 3amps, you would be safe.
BCT7, PRO97<-was run over, PRO164<-to replace the 97, BCT15 w/ GPS, PRO160, PRO2096
And various other electronic toys blah blah blah blah blah
Similar Threads
texas motor speedway medic9351301 Texas Radio Discussion Forum 6 05-15-2009 12:47 AM
scanning in Fort Scott? NosyNeighbor Kansas Radio Discussion Forum 2 03-21-2005 10:17 AM
Question regarding FCC classification code milf General Scanning Forum 6 05-21-2004 01:22 PM
