Go Back   The RadioReference.com Forums > Topic Specific Forums > CB Radio Forum
CB Radio Forum Discussions regarding Citizens Band Radio (CB)
Old 06-12-2009, 07:25 AM
James_Bond_007's Avatar
Default Homebrew Andrew DB-408 Type antenna on 27mhz
anyone ever try to redesign an andrew db-404, db-408, or db-420 for 27 mhz?
DB404
GMRS Outlet LLC*::*Antennas*::*Fixed Antennas*::*Andrew DB404 UHF Dipole Antenna - 3.8dB
DB408
GMRS Outlet LLC*::*Antennas*::*Fixed Antennas*::*Andrew DB408 UHF Dipole Antenna - 6.6dB
DB420
GMRS Outlet LLC*::*Antennas*::*Fixed Antennas*::*Andrew DB420 UHF Dipole Antenna - 9.2dB
the 408 and 420 would probably be too large to be practical at 27mhz
but i'm interested in the results if anyone has ever tried this.
the advantages are decent gain, wide bandwidth vs. frequency, good swrs without need for tuner.
Thank You,
James_Bond_007
Old 06-12-2009, 10:10 AM
rfradioconsult's Avatar
DB made a low-band (nicknamed a trombone) antenna utilizing the folded dipole elements; you could use 1, 2 or 4 elements. However, it had to be installed on the side of a tower with suitable vertical spacing. Thr size and spacing would preclude installation in a stand alone antenna.
Old 06-12-2009, 09:59 PM
kb2vxa's Avatar
In a nut shell, it ain't gonna happen. You could build such an antenna system from scratch but it's physical size alone precludes any practicality.
73 de Warren
Amateur Radio KB2VXA
Station powered by atomic energy, operator powered by natural gas.
Similar Threads
CAl Fire Air Ops "South Ops" connerspears California Radio Discussion Forum 23 06-30-2009 10:35 AM
Homebrew Scanner Antenna? eahuntley Antennas and Coax Forum 15 07-02-2008 07:04 PM
Figuring Out Antenna Type (Ducky) MetalCarnage Antennas and Coax Forum 3 03-21-2006 11:45 PM
What Type of antenna for a scanner xenonmatrix Antennas and Coax Forum 12 05-26-2005 11:59 PM
RS 800Mhz antenna on RS Pro95 handheld radunn Antennas and Coax Forum 27 09-23-2004 10:44 AM
