Go Back   The RadioReference.com Forums > Topic Specific Forums > CB Radio Forum
CB Radio Forum Discussions regarding Citizens Band Radio (CB)
Old 07-15-2009, 10:17 AM
Send a message via AIM to drock2
Default Interference - Engine Noise
If I use my CB while driving I seem to pick up engine noise through the speaker. Both the radio and antenna are grounded. The CB isn't wired directly to the battery, which I've heard could be a problem. I've also seen filters. What would be my best bet for fixing the problem?
Old 07-15-2009, 11:19 AM
va3hub's Avatar
Talking
The solution is to put a "Choke Filter" in line on the positive power feed.
I was able to get information on the WWW about this filter.......The NF-20 is one of the best DC power line filters on the market today. Better than the filters offered by the big chain stores. Handles up to 10 amps at 16 VDC maximum.
Tech Tip: If you plan to use this filter with a CB radio, you should test to make sure that the noise is actually coming through the power line. Simply disconnect the coax from the radio. If the noise disappears, the noise is coming from your antenna and a power line noise filter will not help you. If the noise remains after disconnecting the antenna from the radio, the NF20 should work for you.
I hope this helps.
Old 07-15-2009, 04:29 PM
Thanks for the help. I'll have to try it out with the antenna disconnected.
Old 07-16-2009, 01:47 AM
va3hub's Avatar
Talking
Right on dude !.......just be careful not to key the mic with your antenna disconnected
Old 07-17-2009, 07:48 PM
if you find the noise is coming thru the antenna, then take a look at k0bg.com site for tips on grounding (bonding) etc, to reduce your noise.
Old 07-17-2009, 08:02 PM
gewecke's Avatar
Post
Opinions will vary on this,but another option would be to supply power to the radio direct from the battery using shielded cable such as a length of rg58. the center conductor to pos. and shield to ground of course.
I don't suggest using your vehicle's fuse block,because that can introduce the noise you're hearing. Although a filter as mentioned could be used too,good shielding often cures or reduces the problem.
N9ZAS.
Old 07-19-2009, 08:57 AM
va3hub's Avatar
Talking
N9ZAS.
Holy Cow !...no rope and use it as a boat anchor reply to fix his noise problem ? lol, just kidding
Old 07-19-2009, 10:44 AM
Cool
If it is noise from your alternator, then here's a good filter: NS1535: Antenex (Laird Technologies) Blackhawk Noise Suppressor 35 Volt 15 Amp
Old 07-20-2009, 09:19 AM
BNSFrailfan's Avatar
Send a message via Yahoo to BNSFrailfan
You should post.....
DO NOT push the PTT Mike when the Antenna cable is disconnected from the Radio. That is a no no. You could severely damage your Antenna transmitter and the Radio. I found out the hard way.
Allan Love Jr
Train Photographer
Old 08-02-2009, 04:54 PM
Just finished rewiring the radio. It was getting power from the cigarette lighter so I wired it directly to the battery. What a world of difference! Thanks for all the pointers. That k0bg.com website is great too.
Old 08-02-2009, 10:53 PM
kb2vxa's Avatar
Now the question is how to get rid of all that noise with the antenna connected? (;->)
73 de Warren
Amateur Radio KB2VXA
Station powered by atomic energy, operator powered by natural gas.
Old 08-04-2009, 02:51 PM
va3hub's Avatar
Talking
Are you talking about the SQ noise ? If so, all you have to do is turn the knob to the left till it goes away :0)
Old 08-08-2009, 11:22 AM
Hello Drock2:
Look up the ARRL RFI Book, it covers many RFI and EMI Interference issues. Its at:
ARRLWeb: ARRL Product Catalog
Most good radios will have a NB (Noise Blanker) on the radio that does a good job reducing some pulse type noises. Wiring the radio to the Battery is a good call. Both polarities.
Hope this helps
Jay in the Mojave
Similar Threads
Computer Interference Harmful??? policefreak General Scanning Forum 11 07-03-2007 11:29 PM
Engine Noise and the Pro-96 Gymbag Radio Shack Scanners 9 01-15-2006 12:28 PM
Can anyone ID this type of interference? brandon HF/MW/LW General Discussion 3 01-02-2006 09:10 PM
800 MHz. and the Interference Issue Stephen Mc Clure System Administration and Maintenance 15 10-22-2004 12:31 PM
New Chesterfield Fire & EMS unit numbers BoxAlarm187 Virginia Radio Discussion Forum 2 07-24-2004 12:01 PM
