| CB Radio Forum Discussions regarding Citizens Band Radio (CB) |
07-16-2009, 07:34 PM
Cb Frequencys on programmable radio
i have a programmable radio can i program a CB frequency and talk to people over it.
will it work or no
07-17-2009, 09:53 AM
will it work or no
In a word......no.
07-17-2009, 10:30 AM
Originally Posted by Wyandotte
You must be new here. Stand by for a expert opinion from our resident know it all, Professor NJay. He will be here shortly to tell you what you are doing wrong. He'll quote Part 97 rules and regulations. He will explain type acceptance issues. He may even tell you that you put your shoes and socks on wrong. Enjoy. Everyone else does.
OP is Location: yorba linda wherever that may be. None the less, how would part 97 apply?
Frank
RR Wiki Programming Shortcuts
07-17-2009, 10:34 AM
Depends on the radio.
-Sam-
No illegitimi carborundum.
Hangin' on by a thread and it's stretched just a little too tight.
07-17-2009, 12:09 PM
Uniden Product Manager
Most likely your "programmable radio" is an FM, UHF or VHF band transceiver (but knowing more specifically would certainly assist us in quashing your dreams  ).
Technically, that kind of transceiver isn't capable of transmitting using AM modulation on CB frequencies. Legally, you can only transmit in the CB band on a transceiver that has been type accepted for such use (and your radio is almost certainly not). This is true even in the exotic location of Yorba Linda, California.
07-17-2009, 12:36 PM
will it work or no
Like n9emz said...what type of radio do you have ! I could see it being done with an HF transceiver, You need a radio that will transmit as well as receive in order for it to work.
hope this helps.
And if ever you come back with your radio model ,you may get some ham's telling you to use it as a boat anchor or a door stopper,don't mind them,there just trying to show that there superior to you...lol.
The CB Guy is the one driving the Motorcycle.....the rest of them !......well........... you figure it out.
Welcome to the CB forum.
YouTube - Thomas Dolby - She Blinded Me With Science (2009 Digital...
07-17-2009, 01:07 PM
What kind of "programmable radio" do you have?
What frequency range does it cover?
What modes will it do?
Depending upon the answers to any and all of the above could determine as to whether or not you can or can not program "a CB frequency" into it. As far as being able to "talk to people over it", while that depends on several other factors as well.
If, and that may be a BIG "if", you can and are able to legally program those CB frequencies into it and there are others in close vicinity to you that have and use CB radios, or other modified equipment (legal or not), to transmit and receive in those frequencies then, YES, you may even be able to "talk to people over it".
will it work or no
Well, that depends upon any and all of the above...
Cha bhi fios aire math an tobair gus an tràigh e.
07-17-2009, 01:37 PM
Icom Ic-f21
i have a Icom Ic-f21 radio that i recently purchased.
07-17-2009, 06:24 PM
If you have the IC-21, a UHF handheld radio with TX/RX range 440-470MHz, then your answer is a great big NO!!!
You can not program CB frequencies (26-27MHz) into it.
07-19-2009, 11:28 PM
Bob Loblaw
Let me google that for you
It would apply just the same as it would anywhere else in the United States.
07-21-2009, 04:14 PM
"One of Yorba Linda's most famous residents was the late former President Richard Nixon, who was born and raised in the city. The Richard Nixon Presidential Library and Museum is located in Yorba Linda."
07-22-2009, 12:48 AM
John Force Racing is based there too
Ray H, (KI4WBT)
NW FL Counties monitored:
Santa Rosa, Escambia, Okaloosa
Equipment:
BCD-396T
BCD-996T
BCT-15
PRO-84
PRO-2006, (modified)
PRO-2050
07-22-2009, 01:13 AM
Yorba Linda's most famous residents Richard Nixon ? Man........ i wouldn't want to see one of there worst resident.
07-22-2009, 01:26 AM
Famous does not necessarily equate with "good".
12 volt radios are for wimps. Real radios can kill you.
07-22-2009, 10:42 AM
But then again,Richard Nixon did hang around famous people like Jackie Gleason, wich i believe was a good man,Jackie that is........He was a "CB" man.
YouTube - Jackie Gleason for Richard Nixon He's got a BIGGGG MOUTH !!!!! lol
07-22-2009, 12:32 PM
Wonder what Nixon's CB "handle" was? Yep, he was a CB'er too. So was Betty Ford, "First Mama" or something like that, reportedly.
07-22-2009, 01:01 PM
Edited out upon second thought.
For those who are dieing to know what was edited out.
Just too good.
Some posts can be interpreted as either humorous or insulting
When not sure, always assume humorous
If you only find it insulting you have misunderstood my post or I have misunderstood your post
07-22-2009, 02:46 PM
Just too good.
N_Jay your off topic again ! lol
07-22-2009, 02:48 PM
Just too good.
And you don't have to call me "sir " lol
I had to edit some things out,i was getting off topic,
I am able to monitor the CB channels on my FT-840 from Yeasu (i like it soooooooooooooo much )
07-22-2009, 03:32 PM
Just too good.
A classic,,,,,,,,,,,,,,,lol
The professor is at it again,,,,,,,,,,,lol
