Go Back   The RadioReference.com Forums > Topic Specific Forums > CB Radio Forum
CB Radio Forum Discussions regarding Citizens Band Radio (CB)
Old 07-25-2009, 09:27 PM
Send a message via Yahoo to rafale01010
Default maybe a dumb question...
I got a few old antennaes for a cb, 3 were fiberglass whips and 1 was a metal whip with a coiled section about 3in from the base. it opens up, not 3in from the bottom, and has coiled copper i think and goes back to the whip after about another 2-3"and the last whip section is a pretty good length, not as long as my 102" whipthough. Does the coiled section improve reception or something else, i cant remember now. Any input greatly appreciated.
RS Pro-96, RS Pro-164, RS Pro-137, Regency R1070, Uniden BC350C, Uniden BCT12 Stormtracker, McDonald CE-110, Uniden PC78XL
HCFD Station 5 Explorer Post 200 Exp 15, the Lakes Fire Department
Old 07-25-2009, 10:00 PM
w8jjr's Avatar
Send a message via AIM to w8jjr
simply the coil of wire electricly replaces the missing part of the 102'.
so you could have 30'' rod and the coil would be 72'' of wire. More to it, but thats it in a nut shell
Jim
W8JJR
Old 07-25-2009, 10:28 PM
Where would the best pace to put it be at? Right now i have it mounted in th mount i had for my 102"whip, which came out a while back, right on the passenger side of the back bumper.
Old 07-26-2009, 01:16 AM
w8jjr's Avatar
the best would be the 102 1/4 wave at that location. . Best spot would be center of the car- roof.
if size is not limiting.
Jim
W8JJR
Old 07-26-2009, 01:42 PM
Ah, thats what i figured. Where would i be able to just get the magnetic roof mount for the antennae instead of mounting it directly on the hood itself?
Old 07-29-2009, 09:12 AM
BNSFrailfan's Avatar
Send a message via Yahoo to BNSFrailfan
What type of vehicle are you installing your Antenna too?
Allan Love Jr
Train Photographer
Old 07-29-2009, 09:16 AM
N_Jay's Avatar
Yes, and No.
The coil "replaces" the length of the whip "electrically" but not physically.
The coil will have an inductance that is needed due to the whip being shorter then proper to resonate at the desired frequency, but the length of the wire in the coil is not directly related to the missing length of the antenna.
Some posts can be interpreted as either humorous or insulting
When not sure, always assume humorous
If you only find it insulting you have misunderstood my post or I have misunderstood your post
Old 07-29-2009, 09:20 AM
But doesn't the signal going through the "Coil" get speedup before it get's to the Antenna's rod tip?
Allan Love Jr
Train Photographer
Old 07-29-2009, 09:55 AM
N_Jay's Avatar
That is not a good analogy.
Old 07-29-2009, 11:01 AM
va3hub's Avatar
Talking
Analogy's us if you please, and set us straight on what would be a good analogy,keeping the topic posted in mind of course.
Old 07-29-2009, 11:17 AM
N_Jay's Avatar
At antenna at resonance looks like a tuned L/C (Coil (Inductor)/Capacitor) network.
When it is not at its physical resonance frequency it either lacking capacitance or lacking inductance.
You add an appropriate capacitor or inductor at the appropriate point to return the circuit to resonance it the frequency you desire.
I find that analogies are hard to use because what seems like it helps explain it to one person ends up confusing others.
Even if we tried your "speed" analogy, the coil would be said to "Slow Down" the signal, so it takes a whole quarter cycle of time to get from the base of the antenna to the tip.
Old 07-29-2009, 05:02 PM
That helps me out a little, and the vehicle i'm mounting it to, if i can find the right mount, will be a 1994 Toyota Pickup. I really wont care if it'll look tacky, my trucks already has antennaes galore with 2 pieces of metal pipe for flag pole. The only thing i dont want to do is drill a hole in the roof of the cab
Similar Threads
Looking for equipment/ Dumb question paramedic18 Indiana Radio Discussion Forum 5 12-29-2007 12:40 AM
It may be a dumb question but..... Buckskinner33 Aircraft Monitoring Forum 24 01-24-2006 07:09 PM
A dumb question for the experts out there... merlin-7 Antennas and Coax Forum 0 01-04-2005 08:52 PM
dumb question time radiogrrl Trunking Forum 13 12-23-2004 04:24 PM
Looking for equipment/ Dumb question paramedic18 Indiana Radio Discussion Forum 0 11-26-2004 10:19 PM
