Go Back   The RadioReference.com Forums > Topic Specific Forums > CB Radio Forum
CB Radio Forum Discussions regarding Citizens Band Radio (CB)
Old 08-11-2009, 10:59 AM
Default Recommend mobile CB antenna top-mount with wire out bottom center?
I am currently running a K30 mini-mag antenna. I had to drill a hole to get the wire out anyway, so using the mag-mount doesn't make much sense. I am looking for a permanent mount antenna, I believe the "top mount" style would work best, but I specifically want one where the wire comes out the bottom center of the mount. For instance, I looked at the K40 antenna at radioshack, and even though it is top-mount, the wire comes out the side of the thing. Here is a pic of what I am looking for (not an artist!):
http://www.moroccangoldimports.com/MGI/cb%20antenna.JPG
I have searched on here and the Wilson 1000 seems to get good recommendations. I cannot seem to find an image of how the top mount model mounts- as in does the wire come out the bottom center of the mount...?
Suggestions? I am stuck using a shorty antenna as 5 ft just won't work on the top of my STI.
Old 08-15-2009, 08:30 AM
kc0jar's Avatar
Send a message via AIM to kc0jar
IF you want a good setups, get an "NMO hole mount" with a PL259 connector. You can get NMO antennas in the CB range. That's what my setup is and it blows your typical CB junk antennas out of the water.
You know what I haven't had in awhile? Big League Chew....
http://www.radioreference.com/apps/audio/?ctid=790
Old 08-18-2009, 08:54 AM
The Wilson trunk/roof mount (you remove the trunk "base" to make the through-roof mount) simply mounts in a hole in the roof. The coax is under the roof, between the roof and headliner, and completely inside. I believe it takes a 3/4" hole to mount?
It uses a PL259-type connector for the antenna (uses a standard base load Wilson 1000/5000 antenna).
Old 09-20-2009, 03:58 PM
How about this? http://ak.buy.com/db_assets/prod_lrg.../211131008.jpg Just google gumdrop mount.
Old 09-21-2009, 05:30 AM
BNSFrailfan's Avatar
Send a message via Yahoo to BNSFrailfan
Ya, but one thing you must realize is, is distance. Ho far out do you want to get out. If distance isn't a big thing that you don't care for. Then place it any where on your car other than the roof. But if you want "True" distance. Then the "Center" of your roof is your best bet.
Allan Love Jr
Train Photographer
Old 09-21-2009, 07:56 AM
kc4wwu's Avatar
Send a message via AIM to kc4wwu Send a message via Yahoo to kc4wwu
Default Roof Mount CB Antenna
I have to agree, the Wilson 500/1000/5000 is probably one of the best antennas out there, along with K-40 as far as through the roof antennas. I personally think the 102" whip is the best, but probably not for on the roof of a car.. haha. I am not sure if the Wilson is an NMO mount or not, but they do have a permanant through the roof mount style antenna. Look to spend about $60 - $80 for it.
73, Pete
K4QHR
Old 09-21-2009, 08:09 AM
Default 102" Whip.
73, Pete
K4QHR
I agree with you 100%. Nothing can't beat the 102" Whip. Even though I have had a K40 for well over 15 years now.
Allan Love Jr
Train Photographer
Old 09-21-2009, 11:34 AM
I knew somebody that once had a 102 mounted top center of vw bug. He looked like a rc car going down the road.
WD4BRB
RS PRO96
ICOM 2100
ICOM V8
COBRA 29
Old 09-21-2009, 11:36 AM
KF5DCI's Avatar
haha.
BCD996XT, Pro-95, Pro-197, Minitor V, GM300 VHF, GM300 UHF, Yeasu VX-3R, ICOM ID-800H
Old 09-21-2009, 12:25 PM
gewecke's Avatar
Post
If you want an antenna that will meet your requirements then try the Larsen NMO 27S.
Keep in mind it is a hole mount antenna but it is fed through the base of the antenna.
N9ZAS
Old 09-21-2009, 01:07 PM
va3hub's Avatar
Thumbs up
Go with the Wilson.
Old 09-21-2009, 09:47 PM
Originally Posted by va3hub View Post
Go with the Wilson.
I was talking with some of the CB Radio locals down in Council Bluffs and two of them told me to go with the Wilson 5000 Antenna. Go figure.
Allan Love Jr
Train Photographer
Old 09-21-2009, 10:01 PM
I have both a roof mounted Wilson 1000 and a Wilson 5000, these are the through-roof mounts, not the magnetics...
They work better than their magnet-mount counterparts. They transmit better and receive better than the magnetics. And they can be screwed off and capped if not needed.
Old 09-23-2009, 02:38 AM
RodStrong's Avatar
I have a Larsen NMO CB antenna on my work vehicle, and it works great for me.
Old 09-23-2009, 08:22 AM
gewecke's Avatar
Post
Exactly. If you look at larsen's long standing reputation and years in the industry and compare that to Wilson...then it's clear that larsen stands alone as the choice. These offer the removable options also.
But on the other hand,if you like SIZE and an otherwise high profile antenna which will scream out CB then maybe that's the one? Just two observations which come to mind here.
N9ZAS
Old 09-23-2009, 10:00 AM
va3hub's Avatar
Talking
N9ZAS
But on the other hand ...................Go with the Wilson,I had the larsen and it was junk,it is now residing next to Davy Jones locker.
The Ultimate Guide to 11 Meter CB Antennas
Old 09-23-2009, 04:01 PM
gewecke's Avatar
Talking
I had the wilson...it made a good back scratcher,lol!
N9ZAS
Old 09-23-2009, 05:25 PM
whitehelmet1202's Avatar
Send a message via AIM to whitehelmet1202 Send a message via Yahoo to whitehelmet1202
Kinda reminds me of a friend from back home. He had a ragged out Toyota Celica, and mounted his 102" whip in the back center of his bumper.
I love the K40 I've had. Bought it new back in 1992 and still going strong. I even have the mag mount for it when I need to switch trucks, but that hardly happens.
I miss the 102" whip I had, with a 4" flourescent bulb fastened with electrical tape near the top (the whip was fiberglas and stiff). Key up and make the light turn on....
The long whip IS the way to go, since no matching or tuning is required, but the older Larsen style NMO mount antennas worked great on the CB band too, and could handle up to 200 watts easily...
If you can find one, the Spectrum brand of antenna from Motorola works well on CB. They had a version for the 29-39 MHz range, just find a slightly longer whip and trim to tune and you're good to go. I had one of those and a low lying tree limb got it one night. Haven't been able to find one since. The heavy duty spring was good too.
Old 09-23-2009, 06:58 PM
gewecke's Avatar
Talking
I never had a 102" but a buddy did,and I swear he took an evil pleasure from taking out overhead lights and dinging signs! Forgot to mention it was on a toolbox on a ram 3500 4x4!
N9ZAS
Old 09-24-2009, 10:21 AM
va3hub's Avatar
Yep....cant beat the good old 102'' whip.
Similar Threads
Yep ..... Another Antenna Decision Thread ..... Ganuke Antennas and Coax Forum 6 05-16-2009 03:38 PM
texas motor speedway medic9351301 Texas Radio Discussion Forum 6 05-15-2009 12:47 AM
FL. logs 1-29 May 06 BMT Florida Radio Discussion Forum 3 05-29-2006 08:52 PM
scanning in Fort Scott? NosyNeighbor Kansas Radio Discussion Forum 2 03-21-2005 10:17 AM
Is the Blocked Cellular Freq range on Scanners still needed? bear105 General Scanning Forum 52 12-05-2004 09:19 PM
