Go Back   The RadioReference.com Forums > Topic Specific Forums > CB Radio Forum
CB Radio Forum Discussions regarding Citizens Band Radio (CB)
Old 08-19-2009, 08:58 AM
izzyj4's Avatar
Default Back of set antenna for monitoring only
I was wondering how well the back-of-set CB antennas were for receiving local area radio traffic only. Do they pick up half-way decent? No trasmissions will be done on this CB, I have a separate CB with a base antenna for transmitting and receiving.
Old 08-19-2009, 10:41 AM
James_Bond_007's Avatar
They Tremendously suck, big time!!!!
go with a 1/2 wave dipole hung across the room. if it is just for receiving you can place it anywhere and not have a problem. obviously higher equals better.
try to have it in a complete straight line and it will be directional.
this will work 100 percent better then a BOS antenna.
even better a wilson 1000 trucker type antenna with a 102 counterpoise will do wonders, but a dipole is the on the cheap way. an old piece of coax and 2x 102 inch pieces of wire.
Thank You,
James_Bond_007
Old 08-19-2009, 10:43 AM
ps: worked the west indies from a nj apartment in the early 90's on SSB using a cobra 148 and an indoor home made dipole and a D104.
Thank You,
James_Bond_007
Old 08-20-2009, 01:17 PM
izzyj4's Avatar
Thanks James for the information. I will try that. I'm building a listening post, something that I have wanted to do for a while. I got a classic TRC-452 40 channel that I want to keep good since it was my dad's and I have a TRC-453 with SSB that I'll be transmitting on. Thanks again and I'll try the dipole for the monitoring!
Old 08-21-2009, 07:58 AM
here is a couple of neat calculators for coax loss and dipole design.
Coax Calculator
Thank You,
James_Bond_007
Similar Threads
Set Back Antenna for BCD-996T MFD4305 Antennas and Coax Forum 4 11-08-2008 11:05 AM
Back of Set Antennas Smerri Antennas and Coax Forum 1 08-30-2008 02:20 PM
Good mobil antenna set up for Corvette? stingray327 Antennas and Coax Forum 10 03-31-2008 05:00 PM
Back of the set or base antenna? Nordland Antennas and Coax Forum 7 10-08-2006 12:33 PM
My home built indoor loop antenna for my R75 racin06 Antennas and Coax Forum 4 01-31-2005 11:43 AM
