Go Back   The RadioReference.com Forums > Topic Specific Forums > CB Radio Forum
CB Radio Forum Discussions regarding Citizens Band Radio (CB)
Old 08-21-2009, 11:51 AM
Default Handheld CB radio's and SWR
While using a Cobra heldheld CB and an magnetic mount antenna (Wilson 1000), is it of use to tune the antenna? I've never used a handheld and was wondering if this procedure is useful, since this is a handheld? Thanks for any advice.
Old 08-21-2009, 01:19 PM
gewecke's Avatar
Cool
I suppose you can if you want,but it's probably not needed unless someone has already trimmed the antenna? As long as you have the right connector/adaptor it would probably be fine.
N9ZAS
Old 08-29-2009, 06:04 PM
sjlamb's Avatar
The type of transceiver has nothing to do with SWR. Whether your're using a hanheld, a mobile or a base station in the car, the antenna should be adjusted for lowest SWR. After the SWR has been set, if you move the antenna elsewhere on the vehicle, change the cable length, move it to another vehicle or install any additional accessories between the antenna and the radio; you need to re-match the antenna for optimim peformance through the band.
Steve
N3VRX
BC796D - BCD396XT - BCD996XT
Old 08-29-2009, 10:27 PM
Thanks sjlamb.
Old 08-30-2009, 10:54 PM
va3hub's Avatar
Wink
Thanks sjlamb.
Notice he didn't say John........lol
Old 09-02-2009, 07:11 PM
roadranger's Avatar
Send a message via Yahoo to roadranger
Cool ...This here, is the "Rubber Duck"
Well, I guess like a lot of walkie-talkies, the SWR stinks. Probably even worse, the lower in frequency, the harder it is to come up with the proper length of metal. After all, AM CBs transmit on VHF Low frequencies. However, at four watts, it may not matter much. The SWR could remain a little high at that low power respectively. The Hams do it occasionally, with a little help from an antenna tuner.
It's a little impractical for a hand-held radio. Just the same, I have used a CH 14 radio, with a 9v battery supply, compared to a 40 ch Maxon, 9 AA's, and can still talk across the lot to get my messages out.
Usually, these radios, if equipped with the right connectors, should be fitted with the longest antenna possible. The "Telescoping" antenna can be easily adjusted to a proper length for transmissions. I guess you could keep it as short as possible for close range communications ( like in the "Transformers" movie. ) Perhaps keeping it pulled out to it's fullest of length for maximum effectiveness, will do the job right. I guess it couldn't be too long.
Icom IC-V8, tekkom vhf-murs
RS HTX-10, RS PRO 82, RS PRO 91, PRO 528
Alinco DJ-296, DX-70T
Kenwood TS-430S
Two antennas met on a rooftop--, The wedding was O.K., but the reception was great!
Similar Threads
FS: Uniden & Yaesu Radios 89gta Old Classifieds Archives 1 04-06-2009 11:00 PM
Texas Ranger CB Base, Astatic Mobilemax, Palomar Elite 300 For Sale Bluegrass1dcr1 Old Classifieds Archives 20 10-17-2006 06:28 PM
