Go Back   The RadioReference.com Forums > Topic Specific Forums > CB Radio Forum
CB Radio Forum Discussions regarding Citizens Band Radio (CB)
Old 09-04-2009, 12:12 AM
Default Help, I'm Confused!
OK, so I'll start by telling you that I have A Cobra 19 Ultra III in my car and I can hear truckers really well. I've checked the SWR using a Radio Shack SWR/Power meter and it reads under 1.5 SWR when I key the radio, but when I speak into the radio the SWR jumps up to a reading of 2+ SWR. What the heck? My antenna is still attached and in one piece.
Old 09-04-2009, 08:12 AM
LouisvilleScanMan's Avatar
Sounds like someone has taken a "golden screwdriver" to your radio and "peaked it up". Have you taken power output readings?
Bluegrass1DCR1/KI4RDG
Derby City Radioactives
Louisville METRO
REACT ARES RACES SKYWARN
Bluegrass1DCR1.bravehost.com
DerbyCityRadioactives.com
LouisvilleScanMan.com
Old 09-04-2009, 09:08 AM
The SWR reading is measured from a "dead key" point of view, which means, keying the microphone with no audio signal injection, or keying but not talking into the microphone. The SWR will change when you inject a signal or sound, if your SWR is 1.5, then that is ok. don't worry about a thing if the SWR goes up when you talk into the microphone, it's going to do that, it is supposed, and no one took the golden screwdriver to the radio.
Thanks,
Dodgem250
Old 09-04-2009, 09:19 AM
sjlamb's Avatar
Your SWR reading on a "dead key" (unmodulated) is what matters. When in normal operating mode, you should switch over to the "power" setting. It would be normal for the the meter to jump around if you are transmitting (modulating) with the meter in the SWR position.
Steve
N3VRX
BC796D - BCD396XT - BCD996XT
Old 09-04-2009, 09:24 AM
yeah, what I said LOL
Old 09-06-2009, 12:51 AM
OK, Thanks All! I had an inkling that something was at work. I'm glad that it was a matter of simple physics. I checked the power reading and the meter indicated 500 Watts. I thought CBs were 4 Watt?
Old 09-08-2009, 12:37 AM
Do I need to ground my antenna?
Old 09-08-2009, 11:13 AM
Red face
Unless you have some other "equipment" hooked up you are not telling us about, you are not transmitting 500 watts.
Check your meter to ensure the RANGE is set to 20W. When checking power, ensure the FUNCTION switch is set to POWER.
Now, when you key up you should see the needle approach 500. That is on the top line with the "H" indicator. You need to read the bottom line with the "L" indicator, which is 0 to 20 watts. So if you follow the line from close to 500 on top to the hash marks on the bottom, you'll see 100 on top leads to 1 on the bottom, count off 2, 3, 4 hash marks, and 500 on the top is 5 watts on the bottom scale.
OK?
Old 09-10-2009, 01:12 AM
TomMinkler's Avatar
Thumbs up
where is your antenna on your vehicle? if you have it on your bumper or roof it will work just fine... is the vehicle a newer or older vehicle? these things you need to keep into consideration... the reason being if you have a newer vehicle and it is on your roof... you probably need a heavy duty magnet setup for your antenna.. not a rinky dink one from the store. you will be fine if it ia attached to a metal bumper on your vehicle... If you are having trouble still let me know....
what kind of antenna are you using? (steel whip / fiberglass / other) all these things like i said before are all things you need to take into consideration.
-Stitches- 27.3250 MHz Prescott Valley, Arizona 86314
Old 09-11-2009, 01:45 AM
No other equipment is hooked up, I had my meter set wrong...sorry. I have a 102" stainless steel whip. I'll have to take some measurements this weekend. Am I looking for average power output or peak envelope power? What should a typical power reading look like for a stock 4 Watt CB with a 102" whip?
Old 09-11-2009, 06:29 AM
Average. You should see the needle around the 4 watts mark (the hash on the bottom "L" scale before the one that is connected to the 500 on the "H" scale).
(PEP is for SSB and your radio - Cobra 19 - does not transmit SSB. Besides, this particular meter is horrible for PEP readings.).
Old 09-14-2009, 06:50 PM
I have a damaged cable. I'd like to know where to find cable at a reasonable price. Also, is the PL-259 Male connector easy to put on the RG-58/U cable. I have RG6 TV antenna cable, will it work with a CB?
Old 09-14-2009, 09:59 PM
TomMinkler's Avatar
RG6 will NOT work. that is cable COAX not CB Radio Coax RG 58/u is decent COAX... if you want to get better try RG8/u you can find either at radioshack or possibly any electronics store.. like frys electronics ... as for the pl-259 connections you can also get them at radioshack or Frys Electronics...
Old 09-15-2009, 05:40 PM
i am from ontario and on channel 6 i seem to pick up people from down in the states?? anyone else?
Old 09-16-2009, 01:37 AM
va3hub's Avatar
Smile
I pick them up also.
Old 09-16-2009, 12:32 PM
015reddog's Avatar
They call that channel the "Super Bowl." A bunch of CBers use great big linear amps and all try to out talk each other on that one. You can hear them from all over the country. Funny.
Red
Old 09-17-2009, 11:19 AM
va3hub's Avatar
Talking
Red
Cool,thanks for the info.
Old 09-17-2009, 02:41 PM
anyone in the perth ontario area on cb??
Old 09-18-2009, 10:16 AM
any ideas for home made antennas?
Old 09-18-2009, 11:08 AM
015reddog's Avatar
Default Way off topic
Your question would get a lot more attention as a new thread. This is getting way off topic anyway.
Just a suggestion,
Red
Similar Threads
Totally confused on 800MHz talkaround or direct communications. altec General Scanning Forum 20 02-28-2009 01:59 AM
RS employee, was he helping me or making me more confused? Zik43 Radio Shack Scanners 25 01-12-2009 11:01 PM
Confused, did I buy the right thing? HHIslander South Carolina Radio Discussion Forum 9 08-09-2008 10:02 PM
I'm confused den_1956 General Scanning Forum 10 03-12-2007 10:39 AM
bc796d hallucination ? Mylan Uniden Scanners 3 11-10-2004 10:16 PM
