Go Back   The RadioReference.com Forums > Topic Specific Forums > CB Radio Forum
CB Radio Forum Discussions regarding Citizens Band Radio (CB)
Old 10-10-2009, 11:36 AM
Default Base Antenna suggestions
I live in a community that doesn't allow antennas. A couple things.
Correct me if I'm wrong But I suspect a car radio type antenna (Wilson) would not be effective unless mounted on something metal so that wouldn't be good at home.
I would prefer a good half wave Base antenna with no radials that I could crank up and down as needed.
In the old days I had a 5/8 wave length vert - worked great but had 3 ground plane radials - so that wouldn't work
The simple question is What type antenna would be best for my circumstances?
Old 10-10-2009, 12:19 PM
Highlander_821's Avatar
A Solarcon A-99 might work for you. It is an end-fed 1/2 wave stick, no radials.
Old 10-10-2009, 12:42 PM
MPSCS's Avatar
Disguise it as a patio umbrella post!
Old 10-10-2009, 06:17 PM
2beers4me's Avatar
If you have some trees you could try hiding a half wave dipole antenna. It would be a better dx antenna than local, but would beat having to set it up, and take down all the time. It would be cheap to build, or buy. The Wilson would not work out unless you had a metal roof, or big metal object to put it on. Depending how far your parking space from the house is, you could always run enough coax to the car for a temporary solution.
Old 10-10-2009, 10:59 PM
James_Bond_007's Avatar
1/2 wave coaxial type antenna hidden in a fiberglass flag pole.
want to work 160-6 then a long wire up a fiberglass flag pole with buried ground radials and a tuner at the base.
lots of possibilities for a hidden antenna. all depends on how anal the RF police are where you live.
Thank You,
James_Bond_007
Old 10-11-2009, 09:37 AM
I found something at copper electronics.com ita a bolcony antenna its only 3ft handles 100 watts $37.95 may not be what you are looking for but is another option to look at.
Old 10-11-2009, 09:41 AM
They work good. they must be installed properly. the coax needs to be cut in multiples of 1/2 wave length about 17ft depending on velocity factor of the cable. other wise you get high swr reading even if the actual antenna has good swr. Don't bother trying to run 100 watts into it as it won't take it. i would say 25 watts rms max. probably 75 watts peak.
they over rate these things as far as power handling.
also use LMR series cable.
Thank You,
James_Bond_007
Old 10-11-2009, 05:12 PM
bob-the-scanner-man's Avatar
I'll reccommend what was reccommended to me. I was told that it would work if you ground mount an A99 on a post or something, then it could be taken out when not in use-leaving only the post. I live on a hill so antenna height isn't really an issue, but I don't know about your situation. I haven't gotten an A99 yet I was just telling what was said to me.
Center Point Fire/Rescue Explorer
Scanners:
Radioshack Pro-96
Uniden BC246T(w/ RS Telescopic Antenna)
CB:
Midland 1001Z
Cobra 10 Ultra
GE 3-5980A Handhelds
Old 10-11-2009, 06:29 PM
zzdiesel's Avatar
I lived in some apartments in 1984 where antennas were strictly against the rules. They had clothes lines out behind the buildings. They used steel wires on steel posts. I mounted a 102" steel whip on one of the posts. The clothes line wires served as the ground plane. I could slide the wires to adjust the SWR that I connected to the ground braid on the coax. I had the standing wave down to a 1.3 on that rig.
Uniden BCD996XT | Radio Shack Pro197 | Radio Shack Pro-2055 | Uniden BCT-15 - Mobile | Radio Shack Pro-92
Software: Win500, Win97, Win92, Proscan, Freescan & I.D. Tracker
Old 10-12-2009, 08:55 AM
Default Back to Auto style
Since all the suggestions would be difficult, if I go with an Auto style like a Wilson mounted on the corner of the my roof, Would it work efficiently? There would with limited metal except maybe a gutter.
Again correct to those type antennas make use of the cars metal for ground plane effect?
Old 10-13-2009, 08:39 AM
The only problem with the A99 is that it's 18' tall...that's a helluva umbrella. I think the "Patriot" is only 12' and is white fiberglass. If you are going to put something outside anyway, you still have the steel blade with the Wilson to deal with.
A dipole in the trees is good, but the best cb "stealth" antenna I have some across that does not require a ground plane is the Workman Saturn B100. It's short, black, and it actually works pretty well. You will not have quite the performance of an A99 or Patriot, but you will have a good anenna that is barely noticeable if mounted in the right place.
http://cgi.ebay.com/BASE-ANTENNA-Sma...d=p3286.c0.m14
PS: Oh yeah, there is this Firestik "Indoor" antenna, which is just a 5' Firestik whip mounted on a fabricated ground plane assembly. This would be good in an attic if all else fails.
http://www.claysradioshop.com/citize...stick_IBA5.htm
My recommendations in order:
1. A99 - best, but most conspicuous
2. Patriot - Very good, but almost as conspicuous as A99
3. Dipole in tree
4. Workman Saturn B100 - stealth, good performance, outdoor mounting
5 & 6 tie. Any mobile outside or IBA5 in attic
All IMHO
PPS: I would NOT want to hump that A99 up and down, in and out. I have mounted it twice and I don't want to touch it again until I move.
Old 10-13-2009, 10:00 AM
Default Thanks
I think there is enough there to digest all in summary form.
First indications have me leaning to the Workman B100.
Thanks Again
Sandy
PS Maybe you can tell by my call sign, I actually had a CB license - once upon a time.
If I still had it, I'd frame it. And what motivated me to resurrect my interest in CB is an
Internet article Survival Radio 101 (SURVIVAL RADIO 101)
When I get it fired up after 30+ years, it will be interesting to see who is out there.
Old 10-13-2009, 11:49 PM
I have heavily considered a B100, so if you get one please post on here or pm to let me know how well it works. I guess it really boils down to range vs. noticeability.
Good luck with it, and I hope the locals in your area are helpful.
Scanners:
Radioshack Pro-96
CB:
Midland 1001Z
Cobra 10 Ultra
Old 10-25-2009, 05:31 PM
avtarsingh's Avatar
i would avoid those b100 unless as a last resort
they are garbage
all they are is a tuned dummy load
coax length is very critical for this antenna
Old 10-25-2009, 07:10 PM
gewecke's Avatar
Post
How is it your entire community doesn't allow antennas AT ALL? Who is the culprit to tell you this,better yet how is this worded? Does this include amateur radio too?
This blows me away because even your police and fire services are going to use antennas.
There are TONS of low profile and stealthy ways to install antennas but I think I would look into the legality of IF they can tell you what you can't put up! You have my sympathies for that injustice pushed on you.
N9ZAS
Old 10-25-2009, 11:31 PM
You can add a bunch of ground radials made of thin invisible magnet wire or most any thin wire the same color as your roof. Your end result will be about the same as parking a CB equipped van on your roof.
prcguy
Old 10-26-2009, 10:19 PM
kb2vxa's Avatar
"How is it your entire community doesn't allow antennas AT ALL? Who is the culprit to tell you this,better yet how is this worded? Does this include amateur radio too?"
Yup, antennas with the exception of OTA broadcast and satellite reception which are exempt under federal law have been given the axe by CC&Rs in the deed, municipal ordinances and the dreaded HOA Nazis. Hams are fighting an uphill battle but not a losing one, in some areas we're winning ground little by little so there is a ray of hope.
What hasn't been mentioned yet is stealth goes well beyond the antenna, that's not the only thing that attracts attention. RFI can be a dead giveaway so it needs special consideration, clobber the neighbors and it won't be long before they figure it out. Paramount is the avoidance of modified and "tweaked and peaked" radios that tend to be dirty and amplifiers are out of the question, a stock legal rig is your best bet all the way around. Keep the volume down and likewise your voice, sound carries and neighbors tend to be curious to the point of being nosy. Whatever you do never let them in where eyes can see and confirm suspicion! Stealth means secret so always remember when one knows a secret it remains secret, when another knows it becomes news.
Bottom line here is if they find out you'll see a torchlight parade headed your way. Ignorance is bliss so treat them like mushrooms, keep them in the dark and feed them sh**.
73 de Warren
Amateur Radio KB2VXA
Station powered by atomic energy, operator powered by natural gas.
Old 10-26-2009, 10:27 PM
Maybe the OP can get one of those antennas that were on Hogan's Heros...you remember, the vertical that rose from the flagpole at night when they wanted to operate?
editops, I forgot, no flagpoles allowed either...
Old 10-26-2009, 11:39 PM
gewecke's Avatar
Thumbs up
I feel for that guy if his community are really blatant a**es to not understand that radio was around long before tv or dish network! I don't mean to rain on evening tv buffs who suck up to the cable and dish providers but radio enthusiasts have their rights too!
Like warren said,STEALTH can be the secret weapon against HOA's and the like. If he has an attic or some tall trees on his property then he's not without clout!
N9ZAS
Old 10-27-2009, 12:24 AM
If I found myself in this situation of no antennas (which will never happen) and being a licensed hamster, I would run full legal limit with an indoor antenna on bands most likely to disrupt everything and tell them to go pound sand when they complain.
prcguy
