Originally Posted by lowegreg
I would like to install two firestik 4' fiberglass whip antennas. One for a CB and one for a uniden bcd 396xt scanner. I would like them to look uniform and be installed in my stake bed rails. I have a problem though i cannot find a 4' firestik scanner antenna i can only find the 3'.
If you plan to transmit from your CB, then that antenna is (more) critical. If you were only going to receive on your CB, I'd suggest just using a scanner antenna. It won't work as good as an antenna tuned for CB, but it would meet your requirements.
Could i use a 4 foot cb antenna and just get an adapter to plug screw into my antenna?
Could you? Yes. But I would not suggest it. Have you ever noticed that most police cars have many antennas on them and they are all different lengths? You see, radio waves have a "length", and ideally you want an antenna which matches the frequencies you're receiving.
Antennas which work over a broad spectrum of frequencies do various things to be effective for that range. For example, they could use a 'coil'/etc to create one electrical length, while maintaining a different physical length.
If it were me doing this, I'd put in antennas of different lengths. But if you want something that looks even, even if it does not work as good as it could, then the two 4' antennas could "work".
