retractable antenna
n5ims
Probably not what you're talking about, but my Midland portable CB had a telescopic antenna when I got it in 1970. One issue was that it would quickly drop off full power if it wasn't fully extended when you transmitted. I also had a power AM/FM/CB antenna for my car that would raise up when you started the car and collapse down when you shut it off. This was in the mid-70s. It looked close to this one I found with a quick google search Automatic Triband Power Antenna AM / FM, CB
GoNavy
Arkansas - Pulaski County
That's more then I found, probably could wire it up to a switch as opposed to the ignition. Looking for something I could lower or fold back with a switch, to get into the garage, without having to get out of the car and take it off or fold back manually. My garage, like a lot of garages, is only about a foot (from the door) above my AV's roof. Knowing ME, maybe radio control switch to my garage remote, cause I know I'll forget....lol...I can see me knocking the antenna off pulling into the garage. Just trying to be proactive...lol
LtDoc
Oklahoma
I've seen remotely controlled tilting devices for antennas. Never had a need for one so didn't keep track of them. If you're really serious about it (as in they are NOT cheap) I can try to find them again.
- 'Doc
SmitHans
Arizona, USA/Sonora, MEX
I just put a spring at the base of the antenna, never broke an antenna that way - although it sometimes sounded like everything was coming apart as the antenna hit a low overhang.
