Go Back   The RadioReference.com Forums > Commercial, Professional Radio and Personal Radio > CB Radio Forum
CB Radio Forum - Discussions regarding Citizens Band Radio (CB)
Old 03-29-2011, 6:23 PM
swrvninmypala's Avatar
Question cb in my house
i want to hook up a cb in my house using a wilson 5000 ant. i need to know what power source i need to run my cb. and how to hook it up?
Do what you can with what you have where you are.
Pro94/Pro95/pro2055
Old 03-29-2011, 8:59 PM
Well you could just plug it in the wall...and stand back.
n9zas
Old 03-29-2011, 9:44 PM
davidgcet's Avatar
get a DC power supply rated for at least 50% more current than your radio draws at maximum TX. for a CB, i would say get a 13.6VDC 10 or 12 amp power supply and you should be well covered.
Old 03-30-2011, 1:45 PM
kb2vxa's Avatar
Since the Wilson 5000 is a mobile antenna along with the power supply you first must consider using a proper base antenna to use your CB in the house. Oh now here it comes, "What is the BEST base antenna?" <groan>
Old 03-30-2011, 5:55 PM
N4JKD's Avatar
I used to run a 3 amp DC power supply and it worked great for what I needed
Jason Dailey
N4JKD
Old 03-30-2011, 10:32 PM
I respectfully suggest that you get some local, personal help with this matter so that you don't get injured doing this work. Start with the instruction book that should have been furnished with your radio. If you don't have it you can probably get it from the company that made the radio. Don't go outside and start messing with an antenna until you know for sure how to do it; people get killed every year doing this.
Old 04-16-2011, 7:20 AM
Get yourself an astron 7amp 12 volt Fully Regulated power supply ,hook the red wire to the red terminal and the black wire to the black terminal ,turn the power supply on and you are done.I would put the antenna outside on top of a road sign or other metal.Keep the antenna away from structures or you will have reflected transmit power.If you have the cash,buy a Antron base antenna ,put on pole on the roof with chimney straps.
Keep the antenna away from any and all wires that are attached to your home.Copper electronics is the cb guys friend.
Old 04-20-2011, 8:13 AM
ZigZag747's Avatar
Power supplies are great but and unless you have a car battery laying around, a necessity. Don't need anything big, 7 amps are plenty. Now about antennas, your mag-mount antenna was designed to work best on a vehicle, not to say you can't get it to work for you in your house our out in the field. The mag-mount is only half of an antenna (the active side) it uses AC coupling of the RF shield currents to the metal of the car via capacitive currents to provide the second half of the antenna (reflective side). Key to making this work effectively for you at home you would need to have a reflected surface comparable to a vehicle to insure the antenna's resistance matches the radio's...The Wilson 1000, with out the reflective side measures about 36 ohms, your radio would like to work with a matching 50 ohms, so how do you tell if you have a surface good enough for a perfect 50/50 match at your house? Well you can get yourself a SWR meter from a local Pilot gas station or TA truck stop or Radio Shack, read the directions for hooking the meter up to your setup and try to get your readings as close to 1:1...If you readings are too high try to find a metal surface that will give you a better match. The Wilson antenna out of the box is pretty close to being tuned properly to most vehicle surfaces, so high SWR readings at home would lead me to believe the reflective side is not matched...also remember your readings will be effected by your surrounding structures also...If you're looking for a cheap efficient portable base station antenna a hanging vertical dipole antenna made from 18ft of 18awg braided wire for your active end and 18ft of 18awg braided wire for your reflective end would work far better than your mag-mount antenna, especially if you have a tall tree in your backyard...key here is to be creative and have fun and learn something about your hobby...enjoy...
