Go Back   The RadioReference.com Forums > Commercial, Professional Radio and Personal Radio > CB Radio Forum
CB Radio Forum - Discussions regarding Citizens Band Radio (CB)
Old 06-10-2011, 6:01 PM
Default Cobra 29lx and Antenna set up
This Cobra 29lx is a very nice set. I am having problems with setting up an antenna. I already returned the cobra once for irregular readings and have the second unit. I have tried 3 Radio Shack antennas but the SWR seems to change depending on location. This may be a normal thing but not sure. I set up the calibration as per instructions on the cobra on channels 1,20,40. It seems like moving the car 10 feet can change the SWR readings which are set by the calibration by the Cobra. I can get great readings but they change. Than again sometimes the antenna warning comes on when it showing a great SWR and things should be fine. Cobra said to turn the pot for that warning up as its reading incorrectly. What should I do? Ron
Old 06-10-2011, 11:05 PM
reedeb's Avatar
Forget Radio Shack antenna [JUNK, JUNK, JUNK!! ] Get a K40 or Wilson antenna. BOTH are 1000% BETTER. IF you want to drill out the holes get a ball mount and add the best antenna a 102" steel whip..
Old 06-10-2011, 11:51 PM
W8RMH's Avatar
I agree with reedeb. I wouldn't have a RS product if they PAID me.
Old 06-11-2011, 12:41 AM
Awesomeman92's Avatar
I third (if that is such a thing) the motion. RS/Walmart/any big box store antennas are awful. If you want something small(er) and better quality get a Little Wil or K40.
Graduate, Western Illinois University
Emergency Management
Old 06-12-2011, 5:33 AM
redneckcellphone's Avatar
i first had a walmart mag mount. bad bad bad. then went to a wilson lil wil. much better. but after a few years of having it i realized i needed an easier antenna to take off while leaving the mag mount attatched so i went with the k40 range improved as well
Connor - WQND300
LAX146
Old 06-12-2011, 7:59 AM
SWR changing with location/movement is absolutely normal. Everything around that antenna affects it. If the changes are fairly small, or if they change back to something you think is reasonable, then there's no problem. Every antenna will probably have to be tuned at least a little bit. Finding one 'right', right out of the box is unreasonable and you shouldn't count on it.
- 'Doc
