Go Back   The RadioReference.com Forums > Topic Specific Forums > CB Radio Forum
CB Radio Forum Discussions regarding Citizens Band Radio (CB)
Old 02-21-2013, 11:53 AM
Question PA system without CB radio
Hey guys! I’m new to the forum and I got some questions. I’ve been looking into installing a pa system in my car just as a little project. There is really no daily practical use for it…only than to goof around and/or piss off j-walkers or annoying drivers. I know you can get a CB radio with PA abilities, but I really don’t want a whole CB radio installed in the car. So I was wondering if there was a way to have a PA system without the CB radio. My initial thought was to use a momentary rocker switch (mounted on my center console near the shifter) and the stock Bluetooth mic (which is mounted near the front dome light); however, I don’t know if this can be done.
I’m not knowledgeable with how PA systems work, so I need to know what all the system will need to consist of. That is if this setup can be done and is not too expensive (cheaper than the CB radio + PA speaker route).
Thanks for the knowledge and advice!
Old 02-21-2013, 12:52 PM
freqs's Avatar
CB $35 PA Speaker $9 .you could find use stuff even cheaper .Ive found CB's at Salvation Army stores for 10 bucks
Old 02-21-2013, 1:33 PM
jhooten's Avatar
Temporarily Banned
Go to ebay and buy a used siren and speaker. That will give you about 100watts instead of a few puny watts a cb Pa will give you along with many other annoying noises to use.
Old 02-21-2013, 1:37 PM
WB4CS's Avatar
Be sure to save back a little money after buying your PA. You'll need it for the tickets you'll receive. (Depending on your local laws.)
Brandon, WB4CS
Amateur Extra
Don't sound like a LID! Read this.
Huntsville Hamfest! AUG 17 & 18 2013
Old 02-21-2013, 1:40 PM
I merely just want the system for talking through, not so much the sirens and animals noises and stuff lol
@KT4EB it says you're from Huntsville, Alabama...is that true cause that is where I'm located??
Old 02-21-2013, 3:19 PM
robertmac's Avatar
Angry Wants to piss
off j-walkers and other drivers. WHY? Sounds more like bullying. No wonder society has problems.
Old 02-21-2013, 4:05 PM
I'm not going to be driving around looking for random people walking down the road to yell at. If I'm driving down the road and have a green light and someone decides to just cross the road in front of me, that's when I'll use the PA. If someone crosses the road in front of me when I have the right away, then they obviously either don't care enough to respect the rules of the roads and me on it or they are ignorant and don't know the rules (Ignorance of the law is no excuse). So I will use the PA to respectfully inform them that they are in the wrong. As a pedestrian, you should know how and when to walk...and you should take responsibility for your actions.
And I’m not going to just let them get away with it because that's why they think they can do it. People believe they can do whatever they want regardless of the fact if it is right or wrong because they know that the majority of the time nobody will say anything. So if I say something to that person, then maybe they will think about it next time they blatantly walk in front of someone else’s vehicle.
This doesn’t only apply to j-walkers. If you’re driving home from work and some moron cuts you off without a blinker and can’t keep his/her lane and you can clearly see that person is texting, would you just say to yourself “You silly goose. Why would you do that?”? I’m 100% sure you wouldn’t. So as you just sit in your car and in your mind you go over all the things you would say to them, I’ll be the one who actually does say something. And I will say it in a respectful way because I am a respectful guy, and I do respect other people even when they probably don’t deserve it.
I don’t mean to go on a tiny rant, but I won’t sit here and let someone shoot down what I’m doing based on their biased imagination of what they think I’m doing. I am a new member to the forum, and I respect it and its members. So if you have any positive advice or knowledge for the topic of the thread then please feel free to chime in. However, if you don’t then please keep your comments to yourself.
Thank you.
Old 02-21-2013, 7:10 PM
Hello TT12: Yeah you want a real loud and proud PA System, one that will turn heads and make nut ball drivers wakwe up!
The CB set up doesn't have enough power to deliver the "loud and proud" performance your looking for.
Yoy need a surplus Cop Car or Fire Engine PA System that will gettie up and go. I bought a 80 watt PA Amp from the Ham Radio TRW Swap Meet near the LA Airport, it needs a really good outside high power PA Horn to deliver the goods. I burned up all kinds on cheap CB type horns, and a few that were rated for 30 watts. I finnialy got a 289.oo dollar PA Horn the size of a basketball, mounted just under the Radiator with a clear shot to the car in front, and man does this thing talk.
I don't use it a lot, but when I do its there if needed. Great for the CB & Ham radio get togethers and BBQ's. Tail gaters that get in front of me usually get a blast from the voice above and slow right down.
Feed back from the Incred-O PA System tell me its plenty Loud, yeah!
Good Luck
Jay in the Mojave
Old 02-21-2013, 10:33 PM
Let's start a pool to see how long it takes for him to get cited or arrested for disturbing the peace!
Radio Shack coax doesn't go bad. It's born bad.
Old 02-21-2013, 11:07 PM
W8RMH's Avatar
Don't spend too much that way you won't be out a lot of money after the police confiscate it, and maybe even your vehicle. Grow up.
BCD396XT - BCT15X (Feeder) - BCT15 - Bearcat IV - Yaesu FT60R
_D I S P A T H C E R___O H 1 4 5
________http://www.alertpage.net/________
Old 02-22-2013, 9:35 AM
rapidcharger's Avatar
Location: Bringing you happy thoughts and crunching the numbers daily since 2012
Send a message via ICQ to rapidcharger
OH come on. Let the guy have a little fun.
I have very fond PA-in-the-car memories.
In those days there was no ebay so the cheapest way to get a PA was in a CB radio. Used a weatherproof hailer from Radio Shack mounted under the car.
If you have a CB and your car gets searched, well "It's a CB radio, officer".
If you have a police siren, you're going to have a harder time explaining that.
The output on a CB PA isn't that great but in my experience, it was enough to get through to the person in the car in front of me. If you're lucky you'll have room under the hood for the speaker. The placement of that speaker will have a lot to do with how well you can make use of your limited power. I'm sure you can amplify it too with a little ingenuity.
Old 02-22-2013, 9:44 AM
Thank you.
WOW! Pedestrians have the right of way.... Even J-Walkers... If you hit one your gonna get a citation.
Yelling at the wrong person for cutting you off MAY incite some road rage and get you shot.
If you are so concerned with being a do-gooder and enforcing laws then go be a cop when you turn 21.
Old 02-22-2013, 6:00 PM
Wirelessly posted (Mozilla/5.0 (X11; Linux i686; U; en-US) Gecko/20081217 Vision-Browser/8.1 301x200 LG VN530)
You're also going to run the risk of being the victim of a road rage incident, or even a jaywalker with a gun, regardless of how polite and respectful you are (or think you are) being to them. It's not worth it to try to correct their behaviour.
Old 02-22-2013, 7:25 PM
k3cfc's Avatar
LMAO Where do you live? i want to read about you in the paper.
Don't confuse my personality with my attitude.
My personality is who I am.
My attitude depends on who you are.
Old 02-23-2013, 6:32 AM
In this day and age, you would be dumb enough to taunt other people with a PA? Like others have said...good way to get shot. All around bad idea.
Dave
Dave
My Scanners: Uniden Bearcat BC355N, Uniden Bearcat BC125AT
Old 02-23-2013, 6:56 AM
Hello TT12: One other thing, ya need to have the horn in full front view, if it mounted in the engine compartment not in full view, it will be significantly attenuated, and we don't want that!
For all you negative winnie types, a man needs to know his limits. You guys would have night mirs about my 450 watt 28 Volt Aircraft landing lights, (these lights arn't fom this world in incred-o brightness) they work great with the loud and proud PA System, among other things, hahahha, sorry I am in tears here..
Jay in the Mojave
Old 02-23-2013, 7:30 AM
cknizeski's Avatar
Check you local laws first, you don't want to be a hypocrite.
"People believe they can do whatever they want regardless of the fact if it is right or wrong because they know that the majority of the time nobody will say anything"
Sec. 12-297. Sound amplification systems.
(a) No person shall operate or cause to be operated any sound amplification system, either in a motor vehicle or separate from a vehicle, on any public premises so as to produce an audible sound measured at least 25 feet from the system. Measurement of the audible sound shall be by the auditory senses, based upon direct line of sight.
(b) This section shall make no distinction between stopped, standing, parked or moving motor vehicles.
(c) Possession by a person of the sound amplification system in subsection (a) of this section shall be prima facie evidence that the person operated the system.
(d) Exemptions (1), (2), (3), (6) and (8) of section 12-262 shall apply to this section.
(Ord. No. 86-297, § 4.1.5, 5-8-1986; Ord. No. 93-312, § 4, 5-27-1993; Ord. No. 94-100, § 4.1.5, 2-10-1994)
Old 02-23-2013, 9:24 AM
k3cfc's Avatar
Thank you.
This will be as positive as it gets. grow up stop acting like a 2 year old when they take your lollypop yell and scream at them.smile be a man and see how much better your life will be especially on here.
K3CFC
Old 02-23-2013, 9:35 AM
jhooten's Avatar
Temporarily Banned
BTW, it has been proven time and time again that people who complain the most about other drivers are themselves some of the least courteous and most likely to commit traffic offenses.
Old 02-23-2013, 10:09 AM
RadioDaze's Avatar
My first inclination was to respond to this thread on the grounds of the legal and/or antagonistic aspects of using a PA in a car. But I didn't want to be the "bad guy", "stick-in-the-mud" or "party pooper." (Or worse, "Radio Police.") But I knew others would raise the issue. And they didn't let me down.
Just as in real life, on these forums it sometimes feels like those who would follow the law are "squares." People freely come onto these PUBLIC boards for suggestions on how to break one radio-related law or the other.
"I won’t sit here and let someone shoot down what I’m doing based on their biased imagination of what they think I’m doing."
(No imagination at all; you very clearly stated what you are intending, and it's potentially dangerous. "There is really no daily practical use for it…only than to goof around and/or piss off j-walkers or annoying drivers." Vehicles have horns to accomplish what you want to do.)
"So if you have any positive advice or knowledge for the topic of the thread then please feel free to chime in. However, if you don’t then please keep your comments to yourself."
(I assure you that your PA system will bring out similar but much less restrained reactions from your targets.)
"People believe they can do whatever they want regardless of the fact if it is right or wrong because they know that the majority of the time nobody will say anything. So if I say something to that person, then maybe they will think about it next time they blatantly walk in front of someone else’s vehicle."
"...I’ll be the one who actually does say something. And I will say it in a respectful way because I am a respectful guy, and I do respect other people even when they probably don’t deserve it."
If the irony of all of this is lost on you, you're missing out on some pretty funny stuff.
If you're a teenager, then have at it - it's a rite of passage, and I hope you survive it, as many of us did. But if you're much past the age of 21, you might spend some time considering the direction you're heading.
Sorry to jump all over you, a new member. People who know me here know that I rarely do this. But as in real life, sometimes it's all about attitude.
"'Anybody with fewer radios than me is a loser; anyone with more is a lunatic' may be the quote of the year." -datainmotion
