Hello Ron: The Yagi Beam Antennas when mounted in the Vertical Polarization meaning the beams elements are mounted up and down, just like say a A99 Antenna would be installed, will have little effect from the ground reflections causing a change in the SWR.
Were the yagi beams elements are Horizontal then there will be some ground reflections. So tuning the yagi beam say at ten feet and then raising it to 30 feet you will see a difference in SWR.
Some say you can have the yagi beam resting on the reflector pointing straight up and adjust the tuning (Gamma Match) that way. I have never tried that but some day will and see what happens, I say its worth a try. This hopefully having little ground effect on the yagi beam while tuning it.
One thing I have noticed is, the better the match the less the ground effect has on the yagi beam SWR.
Another suggestion if I may. When assembling the MACO 6 Element Yagi Beam, have some solvent and clean rags to whip off the elements were they connect to each other, as some times in the manufacturing process the elements may have a oil residue left over from being cut. Causing a NO connection between the elements. This I have seen on a few antennas, may have not been Maco tho.
I modified a Maco 5 Element Beam Antenna, removing the Gamma Match tuning assembly and installing a Balanced Hairpin Matching Assembly, (long story) allowing somewhat better performance, and better tuning to dead nutz flat SWR. The owner of the antenna had sprayed oil all over the beam for taking it apart, I had a terrible time getting all the oil out there so the elements would make a good contact and work. Not Maco's fault. The silver lining was that the beam was mounted on a tilt over crank up tower, allowing the beam to be very easily adjusted and tested.
The rewards of a up and running beam are well worth the time and money. The greatest thing I like about a beam is the rejection, allowing me to reject stations from the eastern states to hear the weaker stations out of the south pacific.
Hope this helps.
