Anyone here running a software defined cb radio ??
My Flex 1500 is wide open and transmits from below 1MHz to about 55Mhz including CB if someone was so inclined. I've received some CB stuff and always find it amusing with all the screwed up radios people use that can be 100KHz wide or more on the spectrum display.
prcguy
JayMojave -
Management has to follow FCC regulations re: what frequencies are accessible for transmitting. Unless a radio is being sold as an experimental device it cannot transmit outside the ham bands. My guess is that the FCC would levy some hefty fines to any SDR manufacturer marketing a wide open transceiver. The regulations go further to say that the radio cannot be easily modified to work outside the ham bands. Back in the "good 'ole days" it was as easy as cutting a diode leg to open up certain frequencies and/or features. These days, it's programmed into firmware so it cannot be easily hacked. So, don't blame the manufacturers, blame the lawmakers and/or the FCC. The manufacturers are just following the rules, as they should. While I'd love to have a SDR transceiver that can be easily modified, I'd hate to have one that has no support because the manufacturer went out of business due to FCC fines.
Icom 7300 does MARS TX mod with one diode removal
