Eleven meters dipole project
prcguy
If the wires are short between the dipole and balun yes. Usually a 1:1 balun goes right at the antenna and your coax will run all the way to the antenna. What kind or brand of balun are you going to use?
prcguy
Retroradio
Ontario
Ive run several dipoles on 11 meters. Simple to build and I never used a balun. Out of curiosity, why? Currnetly built a Super Bazooka dipole and it works great.
Are you feeding your dipole with ladder line, open wire as your drawing doesnt look like its fed wirh coax?
Retroradio
Ontario
For 11 meters the wires should be 110 inches, 9.08 feet, per side.
Lots of good websites with dipole calculators for the overall length and each leg length if you want to build iit a specific frequency.
I build mine for ch27 and up as I dont use 26 and down. SWR is good across the band but best were I will use it the most.
prcguy
Make the dipole length as others have mentioned and make the connecting wires from the balun to the dipole as short as possible running the coax all the way to the balun and dipole. You don't need a balun but an effective "current balun" will help isolate the antenna from the coax and make things play better.
prcguy
The wires will je around 20 feet long
