I have a new Cobra 29LX, a new firestick adjustable antenna and all new studs, cable of the right length and such, all mounted to my jeep(yes I know horrible platforms for CB's)
The antenna mount is part of the aftermarket tire carrier and I installed a stainless steel braided ground strap from the tire carrier to the frame rail of the jeep(Very good conductor).
All conductive surfaces are cleaned and free of any kind of coatings. The plastic washer on the stud mount is correctly installed between the top of the stud and the mounting surface(insulating the antenna from ground), leaving the screw on bottom of the stud creating the ground connection
I first tried using the SWR meter on the cb to adjust the antenna and could not get it done. Always 3.0 SWR reading.
Bought a meter from the local truck stop and adjusted it with that. I get around 1.8 SWR and no antenna warning with the meter hooked up to the cb.
When I take the external meter out of the antenna circuit and hook My SWR goes right back to 3.0+ SWR and an antenna warning flashing on the CB. The only thing I have done was to take the external SWR meter out of the loop.
What's going on with this, any ideas.
Thanks in advance, Bruce.
