Channel 6 seems to have a language all its own, which is somewhat related to the Engilish language, but with many caveats.
For example, lets say you want to announce your going to the doughnut shop. You would usually say "I'm going down to the doughnut shop this morning". But on channel 6 you would modify that, announce it several times with a pause between the second and third statement emphasizing specific words and also insert your "CB handle" many times during the message something like this:
Yo, dis is da Grey Ghost and I be go-in down to da doughnut shop dis mo-nin, I say dis is da Grey Ghost, and I be go-in down, I say go-in down to da doughnut shop dis mo-nin. Dis is da Grey Ghost, da Grey Ghost, da Greeeeeeey Ghost, and I be go-in down, I say go-in down, go-in doooown, to dat doughnut shop dis mooooo-nin, and I be back quiet."
As you can see, this language is very inefficient, taking several times longer to get the message across and in most cases the contents of the message is actually less important than the act of sending a message. Practicing this language also has the effect of lowering ones IQ, which may be simply a temporary effect, but in many cases it actually causes a permanent reduction in the senders IQ that cannot be recovered.
I've seen some cases where prior to sending a message over channel 6 the sender converses in a proper "Kings English" then switches to this other language during the sending of a CB message and then returns to proper Kings English when conversing in person. Its a fascinating phenomenon to watch.
