Is there some kind of microphone that will increase my "talk power" or "punch"?
kc0bus
Hi,
I seem to be having a hard time in being heard on the air on CB radio. Is there some kind of microphone I can look for to get that will greatly increase my "talk power" or "punch" or "drive" or "volume" on the air? I'm practically at the point of having to shout into my microphone just so I can be heard at a normal level over the air. Thanks for any suggestions....
IAmSixNine
Dallas, TX
There needs to be testing done first to see if the microphone has an input problem. Covered hole for the microphone comes to mind.
IT could be an issue with the insides not transitioning the audio properly.
Only testing and maybe some tuning will tell you.
prcguy
What brand/model is your radio? An aftermarket amplified mic can really improve your transmission and make your voice really stand out if you get a compatible model.
Hi,
kc0bus
I currently have a Uniden 980SSB
prcguy
If you used the 980 as a base station I would recommend a Shure 526T or a Turner +3, those are the best sounding mics ever made for CB and they work the same on every radio. For mobile use the Turner M+2U and +3 mobile versions would be very old mics needing batteries that are not made any longer.
I've tried the mobile Astatic D104M6B and its not a good match for the 980, no bass and very screetchy sounding. I'm using one temporarily but I was able to equalize out the treble and it sounds ok but I'm still not happy with it.
swen_out_west
Upper Mojave,CA/NV
Another question is whether you use this as a base or mobile?
I have 2 980 ssb's and the audio with the stock mike is horrible and this is coming from a guy whose voice is too loud and usually overdrives other radios. You can do a mod where you open it up and remove the foam, set your mic gain high, it helps a little but still way low.
I put a turner +3 on the one I use for a base and everybody commented how it didn't sound like the same radio. You'll need to learn what setting is best, AM and SSB will have 2 different settings.
I just purchased an Xtreme 2018 (the 2018 isn't the model year, these mics have been discontinued for years) for use with my mobile. Same thing, it isn't the same radio. A mud duck mobile with stadium sounding audio, lol. They are expensive and hard to find. Someone last month put a bunch up on ebay and I think the cost was 65.
Retroradio
Ontario
I use a 980ssb as a base and both the standard D104 lolipop and the modern Astatic 1104c work well on it. It is however a fine line to set the gain on both the radio and the mic as to not overdrive it.
I cant speak to the mobile microphone reccomendation for this radio.
I may be biased but I run Astatic on everything and have for years and IMHO there the best. :)
