Safely...
it depends on the unit. "vintage" means a lot, and there used to be a LOT of radios back then in "vintage" times.
Some could be tweaked to put out 5 watts, maybe 6 or 7. The gain you get isn't really worth the added strain on the finals (which shorten the life).
If you want to put out more than 5watt power, which, if in the USA, is illegal, I would suggest something like a KL203 which can be found in a kit form and fit inside your radio. unlike the RX75, the KL can be turned on/off as needed.
Personally, I would run an external amp. But now that you've started down the road, "it depends" on how much power you want.. More power means: Bigger power wires, Better ground, & a better antenna. Usually, an SWR of 1.5 is the maximum you want to have to not wear out your amps.
I have used the "internal" amp; which is nice but then requires an external speaker. So I prefer using a KL203P external amp (if that power is in your range) as then you get a pre-amp too (and get to keep your internal speaker). My current mobile rig uses a KL503P, and base uses a midnight-special 400; both are "entry level" amp and require filters to keep from splattering to your neighbors' TV...
That's a long way to say "it depends on a lot more than just the radio, it depends on what you want to do"
BUT: Modifying your radio to put out more than 4 watts is illegal (aligning/tuning your radio is not); using an amp on a CB is also illegal. The FCC occasionally goes after CBers that piss off people who complain enough.
