Go Back   The RadioReference.com Forums > U.S. Regional Radio Discussion Forums > Illinois Radio Discussion Forum > Chicago Metro Area Discussion
Chicago Metro Area Discussion - Forum for the discussion of Chicago Metro Area related topics in the State of Illinois. Please post ANY Chicago related posts here.
Old 10-13-2015, 4:07 PM
melvin1987's Avatar
Arrow BERWYN 9-1-1 DISPATCH COMMUNICATIONS 700MHz
Berwyn just received a license for 773.88125 & 774.63125 back in July.
https://www.radioreference.com/apps/...llsign=WQWA615
Old 10-14-2015, 2:44 PM
Showing Phase I and Phase II capable on the license ???....
RoninJoliet
Old 10-14-2015, 10:30 PM
N9JIG's Avatar
Sheriff
Likely intended to replace their T-Band channels.
It could also be used to add to an existing trunked system such as SC21 or CC Sheriff.
Rich Carlson, N9JIG
Facts are facts but my opinions are my own and may not reflect those of whom I work for.
Old 12-25-2015, 6:10 PM
KB9WUV's Avatar
They are now walking around with APX7000 800/700_VHF portables.
KB9WUV
Old 01-03-2016, 9:50 PM
I still hear them on UHF. Are you sure they are not APX7000 700/800 R2 UHF radios?
Old 01-05-2016, 11:14 PM
RADIOGUY2002's Avatar
Based on the fact that their still using uhf I would say its a safe better to say their uhf. Might have been in over sight by looking at the antenna, apx antenna kinda mess with the principle of tring to cipher out what band its really on. They also might be part of the grant, but from them licensing their own frequencies I would say that they might opt out of starcom 21 for a few reasons at the local level. Makes sense long term, wish more departments understood this instead of getting on the band wagon.
Icom F5061/F6061-6, F33-3, F3161-1/4161DT-3, TK380-6, TK3140-1
XPR4550, XPR6550,GP300,HT200,P100,P110, MTX, ICFR3000, VXR-7000D(U)
Uniden=396T/996T, TRX-1
Old 01-06-2016, 9:10 AM
werinshades's Avatar
Maybe it would be a good idea to "give them a listen" before posting?
Old 01-08-2016, 9:29 PM
KB9WUV's Avatar
Could be UHF R2 / 800 MHZ but definitely APX radios. Yes I still hear on UHF also.
KB9WUV
Old 01-08-2016, 10:37 PM
N9JIG's Avatar
Sheriff
The only appearance difference between the UHF/700/800 APX's and the VHF/700/800 ones are the length of the tri-band* antennas. The VHF ones are marginally longer and indecipherable as such without direct comparison.
I just noticed that the freqs are licensed as conventional (non-trunked) so perhaps they will put up a pair of conventional repeaters. They are licensed for both TDMA and FDMA (Phase 1 and 2). I have never heard of Phase 2 being used in a conventional mode but I suppose it is possible...
I still think they intend on adding these to a trunked system, either the Cook County node or the State node of StarCom21. While this would require a new license for a different service type, once they have the freqs licensed it is fairly easy to change.
* The three bands are 700/800, GPS and either VHF or UHF.
Rich Carlson, N9JIG
Old 02-07-2016, 4:48 PM
melvin1987's Avatar
Post Agencies will start migration with an estimated completion by 07/18
https://wireless2.fcc.gov/UlsEntry/a...Ind=applAttach
PD should be transitioned over by years end.
Old 02-08-2016, 1:05 PM
Default DOCUMENT
To their own system or starcom? where the rest of the document?
Old 02-09-2016, 6:12 PM
melvin1987's Avatar
Post RE DOCUMENT
I believe its for their conventional P25 system. That was the only document I came across browsing the web.
Old 05-16-2018, 6:27 PM
ILjim's Avatar
I've had the two frequencies listed programmed into my PSR-500 since I got it last December and as of today have NOT heard a single peep. Not even a key-up or call sign...
Sent from my SM-G965U using Tapatalk
Old 05-16-2018, 6:51 PM
Johnnydollar2's Avatar
Default Berrrrwyn?
Sorry, I had to.
Old 05-16-2018, 8:39 PM
I have them set up as a One Frequency Trunk with both frequencies in the site. As of ten minutes ago, no activity to report. Implementation in July 2018 it says, so keep an ear to it. 2 frequencies, 2 slots each is probably how this will be set up. Might be some low-power usage too, so program accordingly. Keep your fingers crossed for no encryption.
