Go Back   The RadioReference.com Forums > Scanners, Receivers and Related Equipment Forums > Antennas and Associated Hardware > Coax Cable and Connectors
Coax Cable and Connectors - For general discussion of all things pertaining to coax cable, wave guide or any other medium for passing RF energy. This includes connectors, weather proofing and grounding.
Old 07-24-2011, 6:10 PM
sparks40's Avatar
Question Coax question for base antenna
I was wondering if anybody might be able to suggest a good coax for a 100' run for 2M. I've looked at
LMR-400, but it's a little more than i want to spend right now, as this will be a temporary setup. What would the next step down be from the 400? Thanks for your time.
Old 07-24-2011, 6:28 PM
If LMR-400 is a little out of your price range.. then try for some RG-213 and if that's still a little too much of a price then you could always go with but i wouldn't recommend it RG-58.
Old 07-24-2011, 6:41 PM
CalebATC's Avatar
RG-8X is not great for your length by any means, but better than RG-58 and comes at 23 cents a foot at Universal-Radio.
Private Pilot | Amateur Radio General K-4-C-N-G
Monitoring from 30 KHz to 1.2 Ghz, Operating 80-70cm
