Go Back   The RadioReference.com Forums > Scanners, Receivers and Related Equipment Forums > Antennas and Associated Hardware > Coax Cable and Connectors
Coax Cable and Connectors - For general discussion of all things pertaining to coax cable, wave guide or any other medium for passing RF energy. This includes connectors, weather proofing and grounding.
Old 10-17-2011, 12:14 PM
dcorby's Avatar
Question Splitter with cables
I am putting up a new Diamond Discone antenna with a 16 port powered splitter (Multi-Coupler) from Digital Loggers. The antenna run is LMR-400 with Type N Connectors. The length is 100' total. From the multicoupler I am trying to decide what cable to run. Each cable from the Multi-Coupler is less than 30 feet. They will need BNC connectors on each. I was debating on using RG6 Quad Shielded. Will the losses be too great? I am running multiple scanners throughout my house, and monitor frequencies from 37 Mhz up to 800 Mhz. Thanks!
Old 10-19-2011, 8:21 PM
R1VINCE's Avatar
I have the exact same setup as you.
I acquired a partially used roll of RG6-Quad shield and bought my connectors via ebay and made my own various length pigtails going to different parts of my office. Also, I would suggest different colored heat shrink to color code your connectors on both ends for easier reference.
The connectors that I got are the "twist" on style.
My Youtube page
Old 10-23-2011, 9:33 PM
mpddigital's Avatar
What you are doing will work. The LMR-400 run to the antenna will not match with the 75 ohm rg-6 but the mismatch will not cause much additional loss in scanner use.
Old 10-24-2011, 2:48 AM
n5ims's Avatar
That's a nice looking setup, but I would suggest a few changes. You can get some BNC connectors for RG-6 that are very easy to install and work much better than the twist on ones. These connectors (FS6BNCU compression connector for RG6 or the right angle version FSBNC6URA compression connector for RG6) use the standard compression tools used for the standard Cable-TV F connectors. They're commonly used for CCTV or home theater installs, but work great for BNC scanners. The ones I linked to are simply to show you what's available so Google "BNC Compression Connector" to help find the best price, etc.
Also instead of simply color coding the cables, get one of the label makers and some clear shrinkable tubing. That way instead of remembering that the short yellow with long pink is the living room you can simply read the label (the clear tubing is simply to protect the label from dirt and prevent it from working loose/falling off).
Old 10-25-2011, 10:37 PM
R1VINCE's Avatar
My setup was actually like that some time ago. Im not saying in anyway that your suggestions are not good. They are in fact what I had initially done to get my radios set up. I changed from that setup to what you currently see in the above pic. I changed for a few reasons:
1. I actually have a Brother label maker that I used to label all pigtail ends with. It worked fine, but I found myself picking the wrong one anyway when assembling my radio hutch together because all the labels were "white" in color and all looked the same anyway when reaching from behind a shelf to connect. All pigtails come from the same place, but not all are the same length. So switching them back and forth was trial and error in some cases. I found the colors to be a lot more beneficial in quicker identificationI(although I dont seem to be back there all the time anyway).
2. I couldnt find crimp style connectors with the center dielectric foam surround that I wanted to have.
I used to use crimp style connectors on all my connections. But I didnt have enough when I switched from 8way to 16way. So i used an extra pair of these twist-ons. I noticed a small but significant difference in the amount of noise and lack of spurious signals coming in on a particular radio. That one radio had the only assembled pigtail with the twist-on BNC's.When I switched the cable to the crimp-on the noise and spurious activity was back. I moved the twist-on set to another radio, and the same results. My squelch settings got tighter and the spurious activity decreased. Same RG-6/Quad from the same spool, just different connectors. I dont exactly know the science behind it, but I switched all my connectors over to the twist-ons and experienced much better results on all my receivers. Im guessing that that missing center dielectric foam in the middle has something to do with it.
I had a hard time trying to find crimp-ons with the center foam for RG-6/Quad. There are a few out there, but were expensive or I had to buy in huge bulk, and/or it took 6-8 weeks delivery from overseas.
This pic shows the Twist-on BNC on the left and the Crimp-on style BNC on the right.
Im sure you can all see the difference - I can hear it!
My Youtube page
Old 10-25-2011, 11:37 PM
jfhtm350's Avatar
To me it looks like the white insulator is supposed to be there, just missing. Why would they make connectors without the insulator like that? You are right not to want the connector without the insulator.
Old 10-25-2011, 11:49 PM
prcguy's Avatar
BNC connectors without the dielectric insulation around the pin are usually 75 ohm versions.
prcguy
Old 10-26-2011, 12:10 AM
jfhtm350's Avatar
Well let me ask you this if you know. If one of those connectors is a 50ohm and the other is a 75ohm, what is the difference besides the insulator? Is one made for a bigger wire or something? There should not be a difference in resistance if you measure them both with a multimeter in my way of thinking. Couldnt you use a 75ohm connector on a 50ohm cable and vice versa and it still be the same thing is basically what im asking.
Old 10-26-2011, 12:14 AM
jfhtm350's Avatar
I see a difference on the outer rim of the connector at the base. One has rounded semi holes cut out and the other has squared semi holes cut out. I guess that must be so that it fits the correct ohm bnc connector, right? But other than that couldnt you use either one?
Old 10-26-2011, 12:27 AM
gmclam's Avatar
Smile Your setup sounds good
I am running a discone with about 50' of Air-802 coax (sold as LMR-400 compatible) to my splitting station. First I run through high pass and band notch filters before an 8 way multicoupler. I use BNC or N connectors made for the coax with no adapters. I feel this portion of the run is most important since it is unamplified and feeding an amp. The notch filters remove FM broadcast, the strongest signals from the antenna.
That is what I am doing as well -- RG6 quad low loss with BNCs on both ends. My shortest run is 10' and the longest is 70' from the multicoupler. My listening is from 42MHz (CHP) to 860MHz (state parks).
The thing here is that all RG6 (or any type) of coax is not created equal. There is some awful stuff out there, but there is some great stuff too. The loss on the RG6 I am using is less than the loss of many types of RG8 or RG11 at 800MHz. Plus there are several practical issues to deal with such as trying to connect a very rigid coax (LMR-400) directly to a radio. Also, do not forget to terminate all non-connected coaxes. Each output of the multi-coupler should see a 50 ohm load.
PRO-95 | PRO-10 | PRO-97 | PRO-77 | PRO-92 | PSR-300 | PSR-310
Tags
cable, multi output, type
