| Coax Cable and Connectors For general discussion of all things pertaining to coax cable, wave guide or any other medium for passing RF energy. This includes connectors, weather proofing and grounding. |
08-30-2012, 4:41 PM
What Coax for Wellbrook loop to Icom R75 ?
What would be a good coax between Wellbrook ALA1530AL-2 and the Icom IC-R75 ?
My radio will be on the second floor of a 2 story building with the antenna on a rotor on top of the roof.
I live in a highly condensed city with a tiny cement yard so mounting on the ground would not be feasible.
From what I read, Wellbrook doesn't recommend grounding the outer coax from the antenna to the power amplifier box.
I'm looking at a 50 foot run of LMR 240 or the cheaper, more flexible RFC240UF.
I will also be running a #6 copper ground wire up the wall to the antenna mast, but not touching the antenna.
Thankyou for reading
09-01-2012, 8:58 PM
09-05-2012, 11:36 PM
I use LMR240 and love it-strong and highly weatherproof. Excellent shielding. I use it for the scanners as well as HF. I requested your thread to be moved to the proper HF antenna forum.
Unidens BC785D, BC350A on a D130J
'54 Hallicrafters SX-88 #127, Icoms R71A&R75 on 50' random wire @40' SW will never die
RS Pro 2066 in the truck to glassmount tribander
09-06-2012, 7:53 PM
LMR240 and the Wellbrook
Thank you Ridgescan. I will order some and finish this ten year dream of putting up a Wellbrook loop.
I been drooling over these antennas for sometime now and stumbling onto this radio forum site has
re-sparked my love for all that is radio
09-07-2012, 8:10 AM
Glad to hear it  when you're set up come join us in HF and log some DX!
Sorry about the moving thread thing-apparently you are good here
09-27-2012, 8:42 PM
What coax for Wellbrook
Woo hoo ! Got the wellbrook ALA1530 up ! Used LMR 240 ulra flex coax with two BNC clamp connectors.
It's on a Channel Master rotor 9521A, 10 foot radio shack mast and the antenna itself is mounted on a 4 foot fiberglass mast.
I used coax sealer tape on the BNC connector, and on the two joints at the base of the antenna.
Thank you everybody for all the information !
10-08-2012, 2:07 PM
That's a pretty decent antenna - as a rule the thicker the coax is the better. But, do not sacrifice budget on thickness for lack of shield i.e. no matter the brand name/make of the coax and its thickness, it's not a good quality coax if the outer braiding doesn't offer complete and total coverage. A lot of coax from the Far East comes on the Western market at a "good price" because costs have been sacrificed in limiting the amount of material/coverage provided in the braiding.
There are 3 or 4 ways through which poor quality/thin coverage braiding impacts upon received signal quality & strength. The primary downfall is in shielding from "noise" - and the longer the coax is the bigger that will present as a problem.
Faced with the choice of a thinner coax with complete/total braiding coverage, or a thicker coax with a thinner and/or less dense braiding, I'd choose the thinner coax. Its a darn side easier to boost signal strength than it is to deal with the unpredictable nature of coax picked up & introduced noise.
Best coax will have a 100% woven braid covering an overlapped foil winding.
Secondly - coax connectors: good quality connecters are important and where these are outside, covering them and the connecting with self vulcanizing or self fusing tape will keep moisture out. Get any moisture/water into a a coax connector and the braiding will wick it up and along the length of the coax, like a sponge, destroying impedance and capacitance characteritics to the detriment of signal quality.
...... and, as I always say to folk who are listening primarily to a narrow band of freq's - a good quality pass band filter mounted at the antenna will add big time to received and demodulated signal quality.
10-08-2012, 3:43 PM
Hi Mophead excellent combination with the Icom-R75 and the Wellbrook,I use RG213 coax and it does a fine job on hf these are my Youtube videos using the Wellbrook-ALA1530AL-1/ALA1530L Active Loops on
a few different hf receivers..
Moorabbin Airport NDB - YouTube
HF Aircraft - YouTube
HF AIRCRAFT - YouTube
Auckland Volmet - YouTube
Regards Lino..
RADIOS:
ALINCO DJ-X11,ALINCO DJ-X2000,ALINCO DX-R8 (2)
AOR-8200MK3,AOR-8600MK2
DRAKE-SW2
GRE-PSR400,GRE-PSR500
GRUNDIG SATELLIT-750
ICOM-PCR1000,ICOM-PCR1500,ICOM-R3,ICOM-R20,ICOM-R71A,ICOM-R75 (2),ICOM-R2500,
ICOM-R7100,ICOM-R8500,ICOM-RX7
KINETIC SBS-3
PALSTAR-R30A
REALISTIC-PRO2035
RFSPACE SDR-IQ (2)
TEN TEC-320D,TEN TEC-340
UNIDEN-BCT15X,UNIDEN-UBC245,UNIDEN-UBCD396T,UNIDEN-UBCD396XT,UNIDEN-UBC780
YAESU-VR500
+ 50 OTHER RECEIVERS I SHARE IN DADS SHACK
10-08-2012, 3:49 PM
Regards Lino..
RADIOS:
DRAKE-SW2
KINETIC SBS-3
PALSTAR-R30A
REALISTIC-PRO2035
RFSPACE SDR-IQ (2)
YAESU-VR500
10-08-2012, 4:03 PM
Ooo you got the flex-good stuff  I have the straight 240 no flex, but it will give enough to work with. You did a pro job all the way-good on you. Enjoy the toys!
