Go Back   The RadioReference.com Forums > Topic Specific Forums > Antennas and Associated Hardware > Coax Cable and Connectors
Coax Cable and Connectors For general discussion of all things pertaining to coax cable, wave guide or any other medium for passing RF energy. This includes connectors, weather proofing and grounding.
Old 02-07-2013, 6:57 PM
Default LMR600 connectors
I ordered the wrong coax.
Got a 500' spool of Belden 7977A.
Can someone suggest what the best Amphenol N-type connectors for this coax?
Old 02-08-2013, 5:03 PM
mpddigital's Avatar
Bought the best price I see is 15 bucks a piece. Unless you have a press and the dies you will need clamp connectors to do the install them yourself. One that is good is RFN1002-2L2 Product Detail
Times Microwave and Amphenol also make the connectors but they are more expensive
Old 02-08-2013, 6:58 PM
eBay has nice LMR600 silver plated with gold center pin connectors for around $7ea and crimpers for $30. I've used these and the quality is very good.
prcguy
Old 02-09-2013, 10:07 AM
Thanks for the help.
This is for work.
What I spend on the connectors and crimper really isn't an issue.
I thought I was buying the same smaller diameter Belden I usually do, got plenty of Amphenol RFX connectors for it.
I'm not sure I'm gonna use it, hope it bends well, still shrink wrapped on the spool.
Kinda sucks, we gotta carry spools up stairs and ladders. This spool isn't getting on anyone's shoulder.
Old 02-09-2013, 3:51 PM
We use the Times-Microwave, EZ-600-NMH-X. They have gold flashed center spring fingers and an outer crimp ring. Fast and totally reliable for our systems. We only use these and the LMR400 equivalents. We AREN'T regularly doing connections for high power transmitters, just mostly lower power cell repeaters, so I can't say how the spring finger contacts work with 100 W power if that is what you are doing. But all the Andrew type LxTxx and such connectors use spring finger center contacts with high power with no issues.
Get the strip tool and a crimper and be happy......Crimp only once and right up against the backshell body.
IMO.....LMR clamp types are el stinko! We tried them once and would never use them again on work for customers in the field. If you are in an odd place or angle, and cannot strip the coax and handle the connectors perfectly, it's not reliable.
Old 02-28-2013, 6:54 PM
Default Thanks for the help
Thanks for the help. We're only running mobiles on a power supply. No high power here. I'll get some of the Times connectors you recommend.
