Go Back   The RadioReference.com Forums > Scanners, Receivers and Related Equipment Forums > Antennas and Associated Hardware > Coax Cable and Connectors
Coax Cable and Connectors - For general discussion of all things pertaining to coax cable, wave guide or any other medium for passing RF energy. This includes connectors, weather proofing and grounding.
Old 02-09-2013, 7:46 AM
fredva's Avatar
Default UPS Surge Protection for Scanner Coax?
Does anybody run their scanner coax through the TV connectors on a UPS/Surge Protector? If so, is there any noticeable loss in signal? I've read that a BNC to F adapter might reduce the signal by .5 db, so that might be the minimum loss.
PRO-18 upgraded to a WS-1080, PRO-197, PRO-2020, PRO-2021, 436HP, Raspberry Pi SDR
Fire & EMS feeds: http://www.broadcastify.com/listen/feed/527 & http://www.broadcastify.com/listen/feed/3331
Old 02-10-2013, 1:07 PM
mpddigital's Avatar
It depends. Never known anyone who has but that doesn't mean it won't work... But remember - components configured for TV use are 75 Ohm and if you are running 50 Ohm cable there are additional issues.
I good lightning protector is a whole lot cheaper than guiding the surge into something unsure to work that may take many other things down with it.
Old 02-11-2013, 5:58 PM
fredva's Avatar
Thanks for the response. The only relevant spec I could find on this UPS is that it has surge protection of 1,030 Joules.
Old 02-12-2013, 1:58 PM
No. Those are usually horrible connections. I have seen so many signals just plain wrecked going through one of those.
Old 02-13-2013, 8:32 PM
fredva's Avatar
Ok, thanks!
