Go Back   The RadioReference.com Forums > Scanners, Receivers and Related Equipment Forums > Antennas and Associated Hardware > Coax Cable and Connectors
Coax Cable and Connectors - For general discussion of all things pertaining to coax cable, wave guide or any other medium for passing RF energy. This includes connectors, weather proofing and grounding.
Old 11-19-2013, 1:34 PM
LIScanner101's Avatar
Default Trying to locate an NMO-to-BNC adaptor
I came across this on the web:
But I only need the top part (which I assume is an NMO mount with a BNC female on top). I don't need the magmount and coax.
I want to get one to experiment with some BNC antennas I have. Does anyone know of where I can buy one?
Old 11-19-2013, 1:59 PM
Can't say I've seen a BNC (F) to NMO adapter. I have seen a UHF (F) to NMO adapter. You could add a UHF (M) to BNC (F) adapter to it and have what you need.
BB
Old 11-19-2013, 2:35 PM
Thanks but I am concerned with excessive signal loss on SO-239's, especially at 800MHz.
Old 11-19-2013, 2:42 PM
The tenths of db associated with adapters shouldn't cause any problems that you would be able to tell.
BB
Old 11-19-2013, 2:59 PM
My understanding is that adapters per se are not the issue, it's more the use of SO-239's at 800MHz frequencies.
Old 11-19-2013, 3:01 PM
This is the company that makes the S71BNC you have pictured. Get in touch with them, maybe they can help.
Workman Electronic Products - HOME
Old 11-19-2013, 3:23 PM
Thanks, I've sent them an email.
Old 11-19-2013, 3:53 PM
mmckenna's Avatar
I run an 800MHz trunked system, and while we don't use UHF connectors, I have used them on temporary installs. You won't notice a difference.
The right way to do it, rather than trying to use any adapter, is to just install a proper 800MHz NMO antenna. If you are concerned about adapters, impedance bumps, SWR mismatch, loss, etc, then you really need to bypass all adapters and use the correct antenna. An NMO antenna is going to be cheaper than an adapter like what you are looking for.
But, really, you are splitting hairs.
Old 11-21-2013, 9:29 AM
Thanks for the replies. The more I think about it, for what I'm doing ( a quick experiment) I think I can get away with an NMO-to-UHF mount and then add a UHF to BNC female so I can put my antennas on & off quickly.
Old 11-21-2013, 9:40 AM
An NMO antenna is going to go on and off almost as fast as a BNC connector. You really are splitting hairs.
Sent from an unknown place...
Interoperatablity is not a technology, it is an attitude!!!
