I have read some of the other grounding threads but I have some simple questions and like to keep it simple as possible.
I will have a shack outside of the house in a barn, will start with a simple 20-30 foot mast all my equipment now is receive only HF and scanners, I plan to have surge protection and multicouplers, I'm not so much concerned about a strike but I want a good ground to lessen the noise. Here are my questions or concerns.
The shack will be grounded by electrician so assume he will use a ground rod (will instruct and make sure) Can i use this ground rod for all my grounding needs or do my own for Antenna and equipment ground rods?
If I go with a different rod should equipment and antenna ground be the same rod?
any benefit to using separate rods or needs to be the same? Or ground is ground it don't matter?
Does it matter what wire I use to ground with? wide stranded strap type or solid wire with cover? any recommendations?
I'm looking in the net all sorts of ground configs and wire setups photos, some cool looking some not so but the end result is the same, ground with a copper rod in the ground after that anything goes, preference.
Any links on ground rod accessorizes, clamps, plates, etc. Thinking of using some sort of plastic junction box with metal plate as central point for all surge protection, antenna connections with grounding.
