Hello all,
I'm new to this world of radio. I am starting with a scanner with the goal of getting to a HAM license and since I live out in the 'boonies' I'm thinking there's a possibility that I'll need an outdoor antenna to pick up some areas of interest. I don't have the scanner yet so I haven't tested reception with just the indoor antenna yet. I'm just thinking ahead.
I am looking at the Unidens....the BCDx36HP line which covers a pretty wide frequency range. So when it comes to cable I'm wondering the best way to go.
I should caveat that with this factor.....the 'spousal unit' factor! I need to move the antenna away from the old homestead to where it's less apparent. So, I'm looking at a run of around 150 feet.
I understand that most signal loss occurs when you transmit and reception is somewhat less problematic but here's the rub. In order to place the antenna at 'that' location I would have to go underground..... So here are a few issues I'm confused over and would appreciate any feedback to help spin me up to speed.
At that distance (150') and the frequencies covered by the scanner (assuming I can go under ground) which cable is best suited?
Since the goal is HAM later on it wouldn't hurt if I could find a coax that I could use for that also.....just in case...
If I can go underground...does that require conduit or do you just bury the coax in the ground?
Thanks...
SC
Thanks...
SC
