Go Back   The RadioReference.com Forums > Scanners, Receivers and Related Equipment Forums > Antennas and Associated Hardware > Coax Cable and Connectors
Coax Cable and Connectors - For general discussion of all things pertaining to coax cable, wave guide or any other medium for passing RF energy. This includes connectors, weather proofing and grounding.
Old 06-16-2017, 8:00 AM
Unhappy N type plug
I have a moonraker discone that is in my loft and I've been trying for about an hour to get the n type coaxial cable onto it obviously trying to put it on clockwise could anyone suggest why it won't go on ?
Old 06-16-2017, 8:13 AM
photos of connectors might help figure it out.
Old 06-16-2017, 9:06 AM
Daft question - but the one I had a year or two ago had an SO239 socket on the bottom not an N type?
Old 06-16-2017, 10:49 AM
mmckenna's Avatar
The outer part of the male connectors are the same between an N connector and a UHF/PL259. The difference in the center pin. If the N won't fit, then it's entirely possible the antenna has a UHF type connector.
So, either get the right connector or a bigger hammer, your choice.
Old 06-16-2017, 12:20 PM
Here's what N connectors look like...
Old 06-16-2017, 4:57 PM
majoco's Avatar
Read...
antenna
...especially the bit where it says "Connector - SO239"
Old 06-16-2017, 5:04 PM
ko6jw_2's Avatar
Moonraker ads show some models with N connectors and some with SO-239. You can always get an adapter if you don't want to change connecters on the coax.
Old 07-04-2017, 12:55 AM
majoco's Avatar
Well, c'mon - what was the answer - the suspense is killing me......
Old 07-04-2017, 2:09 AM
mmckenna's Avatar
I think we all know what the answer was. Probably why he hasn't commented.
He didn't have a big enough hammer to make it fit.
Old 07-04-2017, 3:58 AM
I've seen PL-259s threaded on to N female jacks. Threaded right on up to the end. You'd think that the female pin collapsing and breaking would be a clue...
Science flies you to the moon. Religion flies you into buildings.
Old 07-04-2017, 2:22 PM
mmckenna's Avatar
I had our PD bring me a vehicle for some radio programming. When I do that I usually give the vehicle a once over, especially since this one had just come back from the upfitter.
Found exactly that. The 800MHz radio had an N connector on the back. The "installer" didn't have an N connector, or didn't know what it was. Anyway what this person had done was to solder the center pin of the UHF connector way down near the base, keeping most of it unsoldered. The unsoldered center pin of the male UHF connector will slide over the top of the center pin of the female N connector.
And, it works. Makes contact and everything.
In the words of Scooby Doo, "and he would have gotten away with it too" if it wasn't someone actually looking at the install.
And this was a big name shop. All I can figure is that it was a new guy, or it was Friday afternoon. Makes me wonder how many other vehicles they've cut corners on, hoping they'd never get caught.
So, off comes the connector, crimp on a new N connector, program the radio, and they are on their way.
Needless to say the 6 new SUV Interceptors that came in when to a different shop.
Old 07-04-2017, 2:37 PM
prcguy's Avatar
I worked with a genius that would always stick a 50 ohm N male connector into a 75 ohm female N connector and completely destroy the connector. They look the same at a first glance but the 75 ohm pin and socket are much smaller and the fatter 50 ohm pin blows the 75 ohm socket apart and shorts everything inside the connector.
In one case the idiot was plugging a spectrum analyzer into a satellite feed 16-way 75 ohm divider and when he didn't get the right signal on the first connector he went down the line destroying most of the connectors on the divider before someone figured out what he was doing.
prcguy
Old 07-04-2017, 4:47 PM
majoco's Avatar
Top marks for ingenuity though!
Old 07-04-2017, 5:40 PM
mmckenna's Avatar
Yeah, definitely premeditated, that's for sure. Who ever it was knew what they were doing, and had likely done it before.
