Go Back   The RadioReference.com Forums > Scanners, Receivers and Related Equipment Forums > Antennas and Associated Hardware > Coax Cable and Connectors
Coax Cable and Connectors - For general discussion of all things pertaining to coax cable, wave guide or any other medium for passing RF energy. This includes connectors, weather proofing and grounding.
Old 11-22-2017, 9:29 AM
Default Replacing BNC connector on radio shack mag mount
I have a radio shack mag mount scanner antenna, the BNC connector on it broke somehow and I need to replace it but when I go to search for BNC connectors it has 3 different types of COAX cable connectors, does anyone know what type of coax the wire for the antenna has, I have never installed/replaced a connector before so I would prefer to buy the right connector.
Thanks!
Old 11-22-2017, 11:57 AM
chief21's Avatar
Chances are high that the cable is RG-58 (thickness less than a pencil). RG8x is a somewhat thicker cable (about the same as a pencil) and RG8 / LMR400 is about one-half inch thickness.
-John
Old 11-22-2017, 12:18 PM
Thanks!
Have you tried looking at the cable? Normally the make and model number is stamped on the cable in white lettering.
Jim
Old 11-22-2017, 8:05 PM
After looking close I found the type: RG-580, was printed very small. Thank you Jim for saying that. Any tips for someone doing this for the first time so I dont screw it up?
Old 11-22-2017, 8:27 PM
mmckenna's Avatar
That'll be RG-58U, not 580. Not that'd you'd find 580, but might save you some frustrationů
Very common coaxial cable for mobile installs. Shouldn't have any issues finding BNC's for that. In fact, I've probably got a bunch in my shop. If you were on the right side of the country, I'd be happy to do it for you.
Old 11-22-2017, 9:04 PM
and I just bought a standard RG-58 connector online, will that still work?
Old 11-23-2017, 11:35 AM
teufler's Avatar
well a standard rg58 connector will work, you will get an adapter to change from a pl259 connector to a bnc connector. If you have enough space behind the radio or on top of the radio, the adapter adds about 1 inch over just a bnc connector alone.
WD0GSYDMR ID 3129226 AND 3129304
BC-396XT,780XLT,TENTEC PARAGON, TYT-2017, MD-390, DM-5R+, ANYTONE 5888,VX10, VX7, VX3,TERMN-8R, F8-HP, GT3, UV-5, UV-3R, WOUXUN UV-8D,JUENTAI UV8DR,
Old 11-23-2017, 12:06 PM
mmckenna's Avatar
Yes. What type of connector is it? Crimp on?
Old 11-23-2017, 1:12 PM
Yes it is a crimp on I got from American Radio Supply.
RG-58/U - BNC-Male Dual Crimp Plug Coaxial Connector (BNC-3822)
Old 11-24-2017, 1:28 AM
mmckenna's Avatar
OK.
So the center pin needs to be soldered. No difficult if you've soldered before.
The ferule needs to be crimped.
Should work just fine for you.
Old 11-24-2017, 10:00 AM
prcguy's Avatar
I think it would be better to have a radio shop or ham radio friend install the connector. If the OP has to buy a crimper it will cost more than the mag mount. Plus there is a chance he will make a mistake and need another connector.
At the very least have someone who is familiar with installing crimp BNC connectors help you the first time.
prcguy
Old 11-24-2017, 10:15 AM
Default right angle bnc connector
Why mess around with the difficult connectors when you can buy a right angle conneector that has a screw on center contact. on ebay
prcguy
Old 11-24-2017, 10:23 AM
prcguy's Avatar
The connector he bought is the absolute easiest to install if you have the correct tools and I can put one on with perfect results in about 30 seconds with the right stripper and crimper. Add a length of hot glue heat shrink as a strain relief and it will be better than new. I would not trust a "no tools connector" on a cable that moves.
prcguy
Old 11-27-2017, 12:01 PM
Redneck0410's Avatar
I replaced one about 7 or 8 years ago with the kind that all you have to do is just trim the outer back about a half inch or so and slide the cable in (leaving the center jacket alone) and it worked perfectly for me. Hell, I just replaced another one on my Larsen Mag-mount NMO antenna with one on Friday and it works like brand new!
Old 11-27-2017, 1:17 PM
cmdrwill's Avatar
I would be glad to crimp on the new connector, but I am on the other coast...
Old 11-28-2017, 10:51 AM
chief21's Avatar
cpg178 - Have you fixed your coax yet? I'm in west central Florida; Where are you in Florida?
John
