| Colorado Radio Discussion Forum Forum for discussing Radio Information in the State of Colorado. |
09-06-2009, 11:52 AM
Pro-2096 "Motor Boating"
Hey guys I have searched and searched so know I am coming to you. I have a pro-2096 and would like anyone that has found a solution for this problem to comment on how to stop this. After some transmissions on my Douglas County feed system I have "motor boating" just after a transmission has finished and was hopping some here has solved this problem and could let me in on the fix. I have tried other forums and was unable to get a solution for this type of system.
09-06-2009, 06:45 PM
Colorado DB Administrator
I think that's been an issue with the Pro 96 and Pro 2096 line. I would check and be sure you have the most recent firmware for the radio installed, and if not, install it and see if that helps.
09-06-2009, 07:25 PM
Also consider reducing the overall control channels you are using sometimes that helps.
Jim<
09-06-2009, 07:47 PM
You wouldn't happen to have the "birdies" on the same frequencies as the Douglas County System by chance?
Rich, Living 1/2 mi north of BNSF MP 24.45 Omaha Line, former BNSF Conductor, Neb. Division, and Firefighter/EMT with Irvington VFD., http://www.irvingtonfire.com/
09-06-2009, 11:56 PM
Yes I do. Have you heard them?
Jim, I know you always preach less is more when it comes to CC I do use alternate CC and will try removing them. I was missing transmissions some time back and added them to correct this but I think I corrected this by using a better antenna.
09-07-2009, 12:06 AM
And try scanning with just one or two sites, should be all you need to cover dougco.
It's been over a year since any metro area site has moved to there alternate CC even briefly I believe.
Jim<
09-07-2009, 12:21 PM
THANKS to all that replied. Jim, I will use Silver Heights, Franktown, Smoky Hill and West Creek CC only and see how that goes, I have seen all of them used on the feed I cover.
09-07-2009, 01:09 PM
When I had my PRO-2096 here in S.E. Michigan, I found going back to earlier DSP firmware (1.2 I recall), helped a lot.
09-07-2009, 05:05 PM
DataBase Administrator
Since this is your feed scanner, what is your decode % on silver heights and Chevron?
If your not mobile, and only trying to monitor Douglas Co., I would only stick in 2 CC's for the feed radio, Silver Heights and Chevron.
09-07-2009, 06:25 PM
Eric, this is how it looked.
Zap = 68-100%
Stanley Canyon = 80-102%
Franktown = 102-105%
Lookout = 48-80%
Smoky Hill = 100%
West Creek = 100%
Silver Heights = 100%
Riley Peak = 70-100%
Chevron = 38%
I live in Founders Village on the hill in Castle Rock. Have listened in today and I have no problems. I do use a RS sputnik antenna and the numbers are lower with the use of a RS discone and the RS800 duck. The sputnik pulls in Colorado Springs well on the Pro-106 thats why I use it. You are correct the 2096 is used for the feed.
09-07-2009, 06:29 PM
Just try programming in Silver Heights and see if that helps with your problem.
09-07-2009, 06:47 PM
I used Silver Heights, Franktown and Smoky Hill and this seemed to work if I only use the two I seem to lose a bunch of transmission from Castle Rock. I checked this by running the 2096 and the 106 side by side and trying deferent tower combos. I will be seeing you soon for a new 197 so I can split my feed.
09-08-2009, 12:26 AM
I am down to one CC and will see if this helps with the noises. Eric it does hit every transmission with a conventional channel helping out Thank you.
